Results 1 to 3 of 3
Thread: 250xs higher compression
01-27-2019, 10:51 AM #15000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
The 2003-2005 250 xs had higher compression and required 91 while the later opti have lower compression and run 87 octane.
how much more compression do they have?
is it due to the heads? Will early heads bolt to a newer (2008) 250?
or is compression due to different shapes pistons?
Or a combination?
how much punch could be gained by swapping? If it’s possible?
01-27-2019, 05:41 PM #2
I did a compression test on my 05 250xs's last week, 129 to 132 psi on all 12 cylinders with 320 hrs on them
Aaron
Fountain 38TE, quad 400 Verados
Talon F20 Flats boat, 250XS
01-28-2019, 02:37 AM #36000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Opti systems hate raised compression they are calibrated to low pressure barely above static compression psi. Ie raise it to much and they back flow.
The aire side functions like a supercharger and can bring operating psi to 160psi -180psi on a 3 cylinder. Think it’s 140-160 on most sixes. Fuels ok at 87 since it’s not heated by compression but added just befor spark( one reason they burn cold and dirty)
more effective power adding is standard turbo, supercharger methods, lowering compression and adding bost and fuel. (I only lost 500rpm at 7000ft but talk about a low end drop out).
See simmons, brat, DBR for real gains.
Never tried swaping heads and fuel air fuel air rail to a 3.2 hummm
many incounter it through shaving heads back in the day. Starved out every cylinder.
Yamaha 115 Head skimming for higher compression
By Gailforce in forum Technical DiscussionReplies: 2Last Post: 09-03-2018, 09:10 AM -
OMC crossflow V6 - Higher compression = better fuel economy?
By kielbasa in forum Technical DiscussionReplies: 3Last Post: 10-22-2017, 11:16 AM -
power gain with higher compression ? or not
By phillnjack in forum Technical DiscussionReplies: 1Last Post: 01-20-2016, 02:17 PM -
Does higher compression = higher EGT?
By SS170 in forum Technical DiscussionReplies: 0Last Post: 09-01-2009, 12:38 PM -
Higher compression/Fuel consumption
By ctered in forum Technical DiscussionReplies: 25Last Post: 07-04-2009, 10:01 AM
