Results 1 to 6 of 6
    Minneapolis MN
    Newbie questions 1700 vs 1708
    Hey guys, moving along with my Viking rebuild and reaching the point where I'm ready to start laying down some high strength cloth. I bought what I thought was 1708. When I unwrapped the roll I found it to be what I believe is 1700. It is a woven 45/45 cloth but does not have any chop/mat on one side Will this work for wrapping my wood transom before install, using it to install transom, as well as above my core once the core is bedded? Also to be used for installing stringers etc.?
    I am using GP polyester resin.
    I have done some research and from what I can find its saying that I should have the chop/mat stitched on the woven cloth to help with adhesion when using polyester. Is that needed? Should I go back and pick up some true 1708?
    Also, is 1700/1708 good for a final layer of glass, or should I cover it with a layer of CSM?
    Thanks!
    Dec 2011
    Ludington michigan,on the shore
    1700 is intended for use with epoxy,it can be used successfully with poly but best over new underlayment. And may not hold as well over old sanded glass. 1708 is best used with vinal or poly,but can also be used with epoxy,problem is the Matt has a binder that is dissolved by the poly, and let's the Matt relax so it will conform to bends.
  3. Thanks tnelsmn thanked for this post
    Minneapolis MN
    Quote Originally Posted by outasite View Post
    Thank you, I'll run back and pick up some 1708 this week.
    Mar 2009
    Port Saint Lucie
    1708 is only 1700 with .75 chop strand stitched on it. If your using poly you can just put a 3/4 oz mat between layers. It just helps bond the cloths together. Mat sticks better.
  6. Thanks tnelsmn thanked for this post
    Likes XstreamVking, capt bart liked this post
    Sep 2016
    McHenry,Illinois
    I've always sandwiched the roving (1700) between the mat (I always use 1 1/2 oz mat), was under the impression that the mat gives the roving a good bond and a good smoother finish on top. Maybe I read your post wrong...if I did...sorry.
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
  8. Thanks tnelsmn thanked for this post
    Minneapolis MN
    Ok, thanks guys. I figured that leaving the 1700 as the final layer wasn't right. Seemed too rough. I'll add some mat over that patch.
    As far as wrapping my transom and stringers and such I won't have enough mat to lay up with the 1700 and the rolls I have are different sizes. So its back to the store I go either way. I suppose I'll just get the 1708. I'll find something to do with the roll of 1700 that's in the garage.
  1. Newbie with Questions
    By Hunt79 in forum General Boating Discussion
    Last Post: 10-13-2011, 07:33 PM
  2. newbie questions
    By niceguy in forum General Boating Discussion
    Last Post: 04-11-2008, 12:52 AM
  3. newbie w/ 460 motor questions
    By sleek78 in forum Technical Discussion
    Last Post: 04-27-2006, 09:22 PM
  4. Newbie, Hello! 200 Optimax questions
    By little vinnie in forum Technical Discussion
    Last Post: 05-14-2005, 07:25 PM
  5. Dumb Questions from a Newbie
    By Roger Steele in forum Technical Discussion
    Last Post: 12-06-2004, 02:01 AM
