Results 1 to 12 of 12
01-22-2019, 12:08 PM #1Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Merc four-stroke 115 ProXs tell-tale temp
Dad’s brand new, 0-hour 2019 115 merc proXS four stroke runs fine, but the tell-tale temp discharge guessing by hand barely got above lake ambient lake temp. Lake was low-mid 50’s and I guessed the stream to be no more than low-60’s even after 30min of on plane, break-in operation. Is this normal, as I’m used to feeling a slightly scalding temp after 5min or so of running.Kevin Kiser
01-23-2019, 07:06 PM #2
I have that motor - and mine definitely gets warmer than ambient.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
01-23-2019, 08:33 PM #3Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Hmm, ok. Maybe we’ll see about adding a temp gauge
Kevin Kiser
01-23-2019, 09:42 PM #4
Ted Stryker thanked for this post
01-24-2019, 01:30 AM #5New Member
- Jan 2019
- Germany
On the 2.1 L the Tell tale goes out before it enters the thermostat. Its quiet normal that the tell tale is just a little bit warmer than the Lake temp.
01-24-2019, 05:12 PM #6Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Ok, that’s more comforting news. Thanks guys
Kevin Kiser
01-27-2019, 05:57 PM #76000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Temp gauge wise, met monitor or smart tach, speedometer just plug in and give about all engine data. If it came with Bluetooth/WiFi it will hook up to a enabled fish finder or your phone with merc app.
01-27-2019, 07:35 PM #8Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
Came with no engine monitoring installed, other than a tach. I assumed all the fancy schmancy new compu-outboards all got sent into the wild with multi data gauges, but I guess not
Kevin Kiser
01-28-2019, 02:24 AM #96000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Not to hard to install if your wanting and have the $$ I suggest the WiFi one these days as it will work with the app and enabled depth finders also won’t confuse the dash.
dhould note it reads water temp in the water jacket not head temp.
01-28-2019, 09:49 AM #10Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
It’s my dad’s engine but I’ll let him know about the options. Thanks Motv18
Kevin Kiser
01-29-2019, 07:26 AM #116000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
The tell tale is before the t stat and doesn't go up or temp much over ambient. With the water temps low this time of year I wouldn't expect the old hand temp o meter to be able to tell a difference
02-01-2019, 11:54 AM #12Screaming And Flying!
- Sep 2003
- shreveport,la
- 5,497
- 18
- 24
- 212
[QUOTE=RSWORDS;3108978]The tell tale is before the t stat and doesn't go up or temp much over ambient. With the water temps low this time of year I wouldn't expect the old hand temp o meter to be able to tell a difference
agreedKevin Kiser
Merc 115/ Four stroke pee temp
By Ted Stryker in forum Technical DiscussionReplies: 7Last Post: 01-29-2019, 05:05 PM -
New Sportmaster Complete Lower unit for new 4 stroke 250R/ProXS for Sale or Trade
By CowboyJoe in forum Lower UnitsReplies: 5Last Post: 11-10-2018, 12:18 PM -
Mercury two stroke engine operating temp pls ???
By merc_racer in forum Technical DiscussionReplies: 4Last Post: 11-10-2012, 01:39 PM -
water tell tale on mariner 4hp 4 stroke
By shakatar18 in forum Technical DiscussionReplies: 4Last Post: 10-30-2005, 03:40 PM
