Results 1 to 6 of 6
    Oct 2018
    San Diego, CA
    Thumbs up 1988 Advantage Banshee 20'
    LOA: 20'
    POWER: 1988 Mercury 2.4 220 carb'd (hrs unknown as there is no meter, compression was good on last test at the end of last season)
    - Ron Hill Marine 26p chopper
    - Hydraulic jackplate
    - Bob's Machine LWP nose cone
    - Optima Redtop
    - Upholstery 9.8/10
    - 10" Grant steering wheel
    - SeaStar hydraulic steering
    - Blinker style trim and jack controls
    - AutoMeter gauges
    - New black vinyl rub rail
    - Holley electric fuel pump
    - Competitive trailer (hubs and bearings brand new)
    - Boat registered through 2019
    - Lower always serviced every 3-4 trips, will be fresh upon purchase
    Cons: windshield is cracked
    Boat is located in north San Diego.
    $10,000 oboClick image for larger version.
ID:	428712Click image for larger version.
ID:	428713Click image for larger version.
ID:	428714Click image for larger version.
    May 2013
    Huntiington Beach Ca
    Clean looking Banshee. Is that a Modvp or a tunnel hull. What kind of top end numbers does it run.
    Oct 2018
    San Diego, CA
    Quote Originally Posted by Baker343 View Post
    Tunnel and not sure on top numbers, as the boat has no speedo or GPS, but def north of 70...maybe pushin 80...had it spinning 6900-7000 last trip with a 26p chopper to give you an idea though
    Bristol, WI
    Quote Originally Posted by MixGasHaulAss View Post
    I've never seen a true tunnel Banchee. You got any pics of the bottom?
    Larry Gempp Jr.
    Oct 2018
    San Diego, CA
    Quote Originally Posted by Speed Jr. View Post
    There’s a center pod
    Oct 2018
    San Diego, CA
    Sold!!!
  1. 1994 advantage banshee tunnel
    By djp in forum Hulls larger than 20'
    Last Post: 07-02-2018, 09:20 AM
  2. Advantage Banshee & Eliminator Scorpion questions
    By Arizona Hotboater in forum Technical Discussion
    Last Post: 05-24-2016, 01:42 PM
  3. Advantage Banshee?
    By H2Oskimmer in forum General Boating Discussion
    Last Post: 08-15-2010, 07:40 PM
  4. 0pinions on advantage banshee
    By thompy in forum General Boating Discussion
    Last Post: 03-24-2010, 08:14 PM
