Results 1 to 4 of 4
    Baldwin N.Y.
    2004 Mercury 250XS
    Hi i just bought a 2004 Mercury 250 XS. It has 575 Hours on it. Should i flow the injectors?? Thanks Steve.
    Feb 2014
    Missouri
    Not unless you feel something is wrong.
    Apr 2017
    Pomona ny
    I would, preventative maintenance is key with opti's. I'd send the entire fuel rail in and get the diaphragm serviced as well
    Mar 2004
    vonore tn.
    All you really need to do, is shock it with quikleen. By shock I mean an extra strong dose of quikleen. Then do a comp. check to see if all cyl,s. are equal in comp. If they are, then definitely replace air compressor. If it is not new black anodized 2 bearing style. The original alum. colored body compressors are only good for about 500hrs.
  1. Twin 2004 mercury 250xs 360 hours 18,000
    By Ralons in forum Outboard Engines
    Last Post: 09-18-2018, 04:15 PM
  2. Replies: 4
    Last Post: 12-20-2015, 07:10 PM
