Results 1 to 5 of 5
01-18-2019, 08:35 PM #1
Measuring cylinder bore, taper, and out-of-round
Hi,
Though I'd share this great video on how to measure the cylinder bore and taper when rebuilding outboard motors
XstreamVking liked this post
01-18-2019, 08:54 PM #2
01-18-2019, 08:58 PM #3
01-18-2019, 09:03 PM #4
Measuring the bore prior to a rebuild will give the machinist an idea of how much material will have to be removed to "clean up" the cylinder. This is how you know what size pistons to order (.015, .030, .060, etc). Due to manufacturing tolerances the actual pistons you are going to use should be measured before final honing is done.
Josh Peterson
noli liked this post
01-18-2019, 10:19 PM #55000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Standard bore on optimax is 3.625 on a perfect cylinder bore
Depending on cylinder condition or problem. Ex out of round, normal wear,or scratches because of bad piston. That cylinder has to bored back to perfect which includes removing material from cylinder bore. Once this is done your standard piston can't b used you have to go oversize..015 or .030 depending how much material was removed. So 3.625 plus .015 or .030 is your new bore diameter.
Rule of thumb for a none Machinist just looking at cylinder bore with scratches if ur finger nail gets hung on small scratches cylinder needs over boreLast edited by 2jz; 01-18-2019 at 10:26 PM.
Measuring the CC's of the cylinder head on omc 56 ci
By phillnjack in forum Technical DiscussionReplies: 2Last Post: 08-27-2017, 02:58 PM -
cylinder bore question.
By N Wolf in forum Technical DiscussionReplies: 8Last Post: 06-18-2014, 03:25 PM -
round bore hub to square bore conversion
By steve@scp in forum Props, Setup, and RiggingReplies: 6Last Post: 02-26-2013, 12:28 PM -
Bore Taper
By chubsta in forum Technical DiscussionReplies: 2Last Post: 11-03-2007, 11:02 PM -
OMC V6 looper: best way to run & break in an out-of-round bore
By foca1 in forum Technical DiscussionReplies: 53Last Post: 09-13-2006, 06:11 PM
