Results 1 to 5 of 5
    Measuring cylinder bore, taper, and out-of-round
    Hi,
    Though I'd share this great video on how to measure the cylinder bore and taper when rebuilding outboard motors
  2. Likes XstreamVking liked this post
    What do these numbers mean when purchasing a rebuild kit for your motor
    Jul 2012
    Lufkin, Texas
    Measuring the bore prior to a rebuild will give the machinist an idea of how much material will have to be removed to "clean up" the cylinder. This is how you know what size pistons to order (.015, .030, .060, etc). Due to manufacturing tolerances the actual pistons you are going to use should be measured before final honing is done.
    Josh Peterson
  6. Likes noli liked this post
    Dec 2013
    georgia
    Standard bore on optimax is 3.625 on a perfect cylinder bore
    Depending on cylinder condition or problem. Ex out of round, normal wear,or scratches because of bad piston. That cylinder has to bored back to perfect which includes removing material from cylinder bore. Once this is done your standard piston can't b used you have to go oversize..015 or .030 depending how much material was removed. So 3.625 plus .015 or .030 is your new bore diameter.
    Rule of thumb for a none Machinist just looking at cylinder bore with scratches if ur finger nail gets hung on small scratches cylinder needs over bore
  8. Likes noli liked this post
  1. Measuring the CC's of the cylinder head on omc 56 ci
    By phillnjack in forum Technical Discussion
    Last Post: 08-27-2017, 02:58 PM
  2. cylinder bore question.
    By N Wolf in forum Technical Discussion
    Last Post: 06-18-2014, 03:25 PM
  3. round bore hub to square bore conversion
    By steve@scp in forum Props, Setup, and Rigging
    Last Post: 02-26-2013, 12:28 PM
  4. Bore Taper
    By chubsta in forum Technical Discussion
    Last Post: 11-03-2007, 11:02 PM
  5. Replies: 53
    Last Post: 09-13-2006, 06:11 PM
