Results 1 to 15 of 49
01-17-2019, 11:06 AM #1Junior Member
- Jan 2019
- Florida
- 12
Any old Force 2 stroke guys out here
I've recently obtained a Force 70 horse 2 stroke 91 by Mercury Marine and in 86 glasstream 15 ft bass boat price was right it gets me going at about 43 mile an hour I am trying to be able to hit 60 with my setup is that possible
FMP liked this post
01-17-2019, 12:19 PM #2Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That's a big jump. That 70 is a big carb single TC, the 90 is a triple, 3 smaller WB carb. You could cut the head for 165 psi , jetting it up a bit, do the cages and reeds, square the transfers, raise a bit and square the ex ports, set the timing at 34° wot running, 35.5°-36° cranking, cut the transfer cover surfaces down a bit, lift the motor and set it back, get a good prop and hope for the best. Or find a 90 and do the above, bolts right(check adapter/spacer year) same weight or find a 4cyl and do the above with about 35 lbs more weight.
With the 70, two/three cylinders are on an upstroke at the same time, 120° crank spacing. When one cylinder is near max intake through the carb the next cylinder is also on it's upstroke, that carb although the larger TC is in competition between the two cylinders. Not sure how much rpm that is limiting but it's happening.
As a comparison, the triple cylinder 25hp lightning Force also shared one carb, that motor does turn impressive rpm into the 6500+ range, so maybe your 70 will as well.
On the 90, three TC adapters made for the 90 in place of the WB would improve high rpm as well in race tune but the 90 with three WB carbs is a good runner.
Better check compression first and see how things look on the 70.Last edited by FMP; 01-17-2019 at 10:16 PM.
01-18-2019, 08:08 AM #3
Wow..... so these ole forces can b a runner huh?? Whod a thunk it, would like to see or hear one
01-18-2019, 08:47 AM #4Junior Member
- Jan 2019
- Florida
- 12
Mine runs about 40 and is not set right. I lifted 31/2 inches and put smart tabs on and redid the carb. And I'm up to 43 now. Trying to hit 65 70 mph. Can't afford a new motor so I have to build one I have . Machine shop can be cheap and I can do the tear down and put back. A grand or 2 is cheaper 10 grand for a new motor. And it's fun to build
01-18-2019, 09:04 AM #55000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
if you are gonna spend 2 grand , just buy an old johnson / evinrude v4....you will be light years ahead of that force...
if you ever get any rpms out of it , it will break the ring lands off the pistons , even with stock head and compression...
JMO after working on junker motors for too many years....
01-18-2019, 09:14 AM #6Junior Member
- Jan 2019
- Florida
- 12
Everything is 4 to 5 grand for anything decent out here by me here in Florida And I already have the force. I'm just trying to keep up with these wkend warrior in these bass tournaments . Don't like the way they smirk and laugh at me and my boat. I just want something me and my 9 yr old daughter to conden with.
01-18-2019, 09:18 AM #7
01-18-2019, 09:21 AM #8
01-18-2019, 09:22 AM #9Junior Member
- Jan 2019
- Florida
- 12
Yes please. That would be much appreciated.
01-18-2019, 09:27 AM #10Junior Member
- Jan 2019
- Florida
- 12
They have 2018 z21 nitro with 250 merks on the back. 65000 boats and they are better than me because of it. So I told my daughter that they are and I can build are up. And I have my work cut out for me.
01-18-2019, 09:29 AM #11
Well nitros suck neway, had lots prob with hulls, now u will never out run one them 250s with ur 70 but if that's what u want. Build er up!
01-18-2019, 09:59 AM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
The triples during the early 90s did well in competition. They were modified, ports, chambers sized, etc . Ran very strong, Mike Wienandt of WPT had good results. Only a 1/2 V6 Merc could get around them at the way top end of a long straight away.
Similar, the triple CHRYSLER Bill Edwards. Has a 70-75mph on a 15'.
Here's one the triples , tunning runs
https://m.youtube.com/watch?v=jtiAF2fWK7I
https://m.youtube.com/watch?v=Q-3_pBF7QR4Last edited by FMP; 01-18-2019 at 10:20 AM.
01-18-2019, 10:07 AM #13Junior Member
- Jan 2019
- Florida
- 12
Not so much out run but out perform they can't reach there top end so if I can hit my Mark I can shut them up on the water by out performing them by hitting that 55 60 mph I can take the inside as well witch is what they can run. I've built many street rods but this is my first outboard
01-18-2019, 10:23 AM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
It's going to take every bit of smarts to hit your goals, but fun trying.
Is it the one piece side bullet water intake lower unit or Merc style?
01-18-2019, 10:27 AM #15Junior Member
- Jan 2019
- Florida
- 12
Merk style... It looks like I might just have to find a bigger motor to hit my goals. So I'm starting to find a 120 force or something similar but to. Going to go with a 2 stroke tho
Air Force One? How about BOAT FORCE ONE!!! MAGA!!!
By home made tunnel in forum General Boating DiscussionReplies: 13Last Post: 09-29-2018, 11:10 PM -
Help guys Yamaha 50 4 stroke carburetor
By skydog in forum Technical DiscussionReplies: 17Last Post: 06-05-2018, 03:45 PM -
Two stroke motorcylce guys, check this!
By Forkin' Crazy in forum The Scream And Fly LoungeReplies: 37Last Post: 09-10-2013, 01:54 PM -
One For The Muummmmmmhhh Stroke Guys
By Instigator in forum General Boating DiscussionReplies: 21Last Post: 05-17-2002, 08:30 PM
