Results 1 to 15 of 28
    Apr 2016
    Victoria bc canada
    What octane to run with 19cc heads
    Just wondering what octane I should run with 19cc domes, engine is a 260 with stock deck heights, its has been ported to drag specs with geiger tec 19cc domes. Thanks for any input.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
    c16
  3. Likes nitro_rat, Dave Strong liked this post
    Jul 2012
    Lufkin, Texas
    mix with klotz bēnol for best smell if not best reliability...
    Josh Peterson
    Aug 2006
    GA
    Nascar Fuel 112 or 114
    Sep 2017
    Ashland city tn
    Not trying hijack but got sum ? How much cranking comp is that and what kinds hp is expected from stock heads? Will hp go up 10 ,20 ,30?
    Jul 2009
    Crawfordville fl
    This kinda loaded question. But not know your exact style of boating. 110vp or 112 sunco is plenty. Timing set a 25 degrees You want have a problem if your squish is right
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
    Apr 2016
    Victoria bc canada
    Quote Originally Posted by bigbluechevy454 View Post
    This will be my drag motor, will be racing 800ft, 25° of timing, running VP c12 would be out of the question?
  9. #8
    Always start ahead of the game and work backwards to what the motor wants. It is far less expensive that way.
  10. Likes powerabout, nitro_rat, Dave Strong liked this post
    shreveport,la
    VP 112 is plenty of octane. Run your timing at 25 degrees
    Erik Kiser
  12. Likes Dave Strong liked this post
    Jul 2009
    Crawfordville fl
    Quote Originally Posted by Brookbbb View Post
    . C12 is a great fuel. You will be plenty safe. If your just drag racing You can creep up on your timing possibly as well. But u need to pay attention to your tune
  14. #11
    Jul 2009
    Crawfordville fl
    If your drag racing I’d also make sure your fuel system can support that if you haven’t already addressed that
  15. Likes nitro_rat liked this post
  16. #12
    Apr 2016
    Victoria bc canada
    I'm running a big Bush pump, 56lb reg, brucato box with an A6 tune, steamwheel up front and dual egts to monitor temps aswell, I wont be running these domes for lake use, 800 ft only.
    Apr 2016
    Victoria bc canada
    Quote Originally Posted by patchesII View Post
    I dont see a VP112 on the fuel list for VP, to confirm, I can run c12 or do I need c16? 108 vs 120 octane
  18. #14
    Jul 2009
    Crawfordville fl
    Vp doesn’t make 112. C12 Is the number. The standard vp110 will also be safe. I’d suggest a little more pump than the Bosch for drag
  19. #15
    shreveport,la
    I’m apparently not up on VP’s race gas offerings. I thought they had a basic 112 like Sunoco has. Either way 110-112 octane is enough
    Erik Kiser
  1. 19cc 2.5 Heads
    By Laser LTV in forum Misc. Parts and Accessories
    Last Post: 03-19-2018, 07:52 AM
  2. 19cc and 26cc heads
    By dagodiver in forum Misc. Parts and Accessories
    Last Post: 12-17-2013, 01:22 PM
  3. Mercury Tech: 21cc heads to 19cc
    By bigbluechevy454 in forum Technical Discussion
    Last Post: 12-11-2011, 08:59 AM
