Results 1 to 7 of 7
01-15-2019, 11:00 AM #1Junior Member
- Jan 2019
- Phoenix
Question for those that have drilled out heads
Hi. I have a 2002 250 Pro XB SN-OT430677. I知 currently looking for some 300 promax heads and have finally found a set. Only potential issue is they致e already been shaved 30 thousandths. I was wondering if anyone could tell me what that would put my compression at as I知 not really wanting to go over 140 psi. Thanks guys.
01-15-2019, 11:41 AM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
JSRE modifys ALL 3 liter head to any desired cc and compression numbers desired by the customer. We also put back stock OEM gasket complying Water and compression side o rings
JSRE ( Jay ) @
832 597 2603Jay @ JSRE
01-15-2019, 12:08 PM #3Supporting Vendor
- 11,838
- 163
- 11
- 795
Last month built a modified 280 , the coustomer requested over 200 lbs cranking compression at sea level , we cut the same water side stock OEM gasketed spaghetti O ring but I’ve found the 225 X triangular compression O ring to “live” better in the O ring heads that come with a normal OEM round o rings , this is things I’ve learned cutting the O ring style heads on motors that make 225 lbs + and some on alky with heavy specific gravity numbers which is like compressing concrete with these triangular shaped OEM 225X compression side O rings the live lots better and available from Mercury or Pro Marine , good luck !
JSRE ( JAY)
specboatops liked this post
01-15-2019, 06:46 PM #4Junior Member
- Jan 2019
- Phoenix
Thanks Jay. If I decide to shave down my XB heads I will keep you in mind. I'm trying to find out the compression numbers if the 300 promax heads shave 30 thousandths.
01-16-2019, 07:12 AM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
The 300X heads are pretty much as tight as I’d run using pump gas , cutting them .030” and trying to run our crappy pump gas premium would be IMO risky ...
JaybJay @ JSRE
01-16-2019, 10:38 AM #66000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
DO u know the bore size on the 250? .o3o should only be a couple of cc-3-4. educated guess from 2.5 shaving. 8-10 psi.
01-16-2019, 12:11 PM #7Supporting Vendor
- 11,838
- 163
- 11
- 795
According to the geographic location ...After cutting litterly thousand of 2.5 heads I find most umbrellaed shaped combustion chambered head yield a loss of CC for every .010” of material you remove you will reduce the CC by .7 ( Take off 030” you reduce CC’s by 2.1 CC’s )
Good luck ,
JayJay @ JSRE
Mercury Tech: 2.4L BP Heads Question
By Tango in forum Technical DiscussionReplies: 6Last Post: 09-04-2015, 07:46 AM -
Question Regarding Heads
By trashy in forum Technical DiscussionReplies: 0Last Post: 10-22-2007, 10:11 AM -
drilled mid section(question)
By david martin in forum General Boating DiscussionReplies: 8Last Post: 03-15-2006, 02:18 PM -
Question about these heads
By 83Enchanter in forum Technical DiscussionReplies: 3Last Post: 05-08-2002, 07:06 AM -
Question On Heads
By Carter Powell in forum Technical DiscussionReplies: 0Last Post: 02-22-2002, 02:11 AM
