Results 1 to 8 of 8
    Tampa, Fl
    3.0L sportmaster prop shaft seal replacement
    I need to replace the prop shaft seals. Is pulling the carrier out required or can it be done from the outside?
    Aug 2012
    Tenkiller Lake, OK
    Best to pull the carrier to do it. I have seen hacks that drill small hole in the seals, screw a screw into them and use a slide hammer to pull it out from the outside. Remember there are at least two seals to remove.
    JAX. FLORIDA
    I have Charlie and Ed pull my carrier each year to inspect my gears and replace my seals and water pump, just as insurance.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I dont know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion. Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
    Pull the carrier there is a seal installer that positions the seals at the correct depth and ensures they are installed square in the carrier.
    Jul 2016
    columbia sc
    Do you know where we can pick up that seal install tool
    Tampa, Fl
    I guess I will run it over to Colabella and have him reseal it. I was just hoping to avoid the 4 hour round trip in the car over just a couple of seals.
    I have the Merc part number but dealer probably would have to order it.
    Part number 91816294.
  1. Mercury Tech: Shift shaft seal replacement: Any tips?
    By mxz in forum Technical Discussion
    Last Post: 05-27-2014, 08:06 AM
  2. 3.0 225 lower unit prop seal replacement?
    By BUD in forum Technical Discussion
    Last Post: 12-29-2011, 06:37 PM
  3. sportmaster prop shaft seal
    By boise137 in forum Technical Discussion
    Last Post: 05-29-2006, 08:43 PM
