Results 1 to 12 of 12
Thread: Leak Down Test
01-11-2019, 08:22 AM #15000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
01-11-2019, 08:39 AM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
My opinions on leakdown testing procedure are a little different than most,and render the most accurate results,again my opinion.Most folks follow the directions and put the piston at top dead...where there's no wear,and usually get low leakdown results accordingly.A poor mans leakdown test is really better,and is faster,cheaper,and easier...do a comp check,just write down the compression numbers,squirt a couple shots of 30 wt oil in each cylinder,spin the motor over a few seconds and recheck the compression...the amount the compression goes up will be close to overall leakdown percents.
Now my way.Follow the normal procedure but instead of locking the flywheel near tdc,pull the motor from ports open to tdc on every cylinder,stopping at several spots along the way,and look at the resulting leakdown along the working stroke of the cylinder.
We do this with a ratchet on the flywheel nut,with a long bolted in place tube extention on the ratchet handle...(3 foot long,specificly for this task).
DO NOT USE A BREAKER BAR for this job...when you pull the piston over tdc the 40-50 pounds of pull required will turn to push and may DE-BRAIN you...the ratchet will allow the flywheel to spin to to open the ports.
This procedure will locate bulged cylinders,scoring above the ports etc.,that a locked flywheel test won't know about.
Also,for the most accurate results check the port side of a "v" motor by pulling the flywheel clockwise,and the starboard counterclockwise to place the piston in its thrust position.I test
at 75 lbs.
I figure if you're going to test you might as well get the best results you can,I should'nt have to tell you to keep fingers clear,and be careful,as the flywheel is going to spin as it goes over tdc,but i will anyway,BE CAREFUL,Chris
bbezok, ssv1761982 thanked for this postFMP liked this post
01-11-2019, 09:36 AM #35000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
pm sent
01-11-2019, 10:29 AM #45000 RPM
- Apr 2003
- Pennsylvania
- 753
- 18
The advice Chris has given you is the very best you will get from anyone. The reason you are seeing the difference between the port and starboard side is that you were rotating the flywheel in the same direction for both sides.
01-11-2019, 10:33 AM #55000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Even though test was done on each @ TDC?
01-11-2019, 11:22 AM #65000 RPM
- Apr 2003
- Pennsylvania
- 753
- 18
01-11-2019, 11:31 AM #75000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
I'll try it that way first chance I have as well as the procedure Chris uses, just a bit leery on eating a ratchet handle......after all, they don't call them "on purposes".
01-11-2019, 11:35 AM #85000 RPM
- Apr 2003
- Pennsylvania
- 753
- 18
01-11-2019, 11:41 AM #95000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
yes, I believe Chris said he does it @ 75lbs but I'm sure 50 will do.
01-11-2019, 11:54 AM #10
I like to turn flywheel and pump it towards tdc like Chris said then you can see the whole picture 50 psi x 2
bbezok liked this post
01-11-2019, 12:22 PM #115000 RPM
- Apr 2003
- Pennsylvania
- 753
- 18
01-11-2019, 12:25 PM #125000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Thanks guys, really appreciate the info.
How to do leak down test on a 2.4 EFI
By bridgeportguy in forum Technical DiscussionReplies: 18Last Post: 12-09-2017, 01:39 PM -
leak down test ?'s
By boilerdawg in forum Technical DiscussionReplies: 35Last Post: 06-08-2009, 08:00 AM -
Leak Down test
By varmint2002 in forum Technical DiscussionReplies: 14Last Post: 05-30-2008, 01:04 AM -
Leak down test
By marshan162 in forum Technical DiscussionReplies: 0Last Post: 06-07-2004, 06:15 PM
