Results 1 to 4 of 4
    Jul 2017
    South Africa
    1983/88 Mercury 115 Technical Questions
    Good Day, my brother (mainly) and I have restored a 1966 Boat Locker "Malibu" The boat originally had a 1965 Mercury 1000 6 Cyl. Unfortunately we could not save the powerhead.
    We opted to get an 80s model 6cyl with PTT, and the newer ignition system, in order to make it a bit more practical to use. After a year we managed to build a inline 6 with the 88 lower unit, PTT and gearbox, and an 83 Powerhead.
    I have experience with OMC andthe Japanese brands, but 0 on Mercury and even less on inline 6s
    here is a pic,with 66 decals on, contemplating if we must do the 66 engine coversand chrome beadings.
ID:	427809Click image for larger version.
ID:	427810Click image for larger version.
    issue 1:
    Cooling system
    Engine running water is coming out of pee-hole AND a tube on the water jacket between the spark plugs
    put a hose on it routed to the engine tray to prevent water from being sprayed over plugs
    , what needs to happen here, and why is there an outlet on the water jacket?
Name:	Pee hole.jpeg
    Issue 2:
    Motor starts, idles, a bit rough, and runs great for a few minutes, then it goes into a limp.
    Action taken
    Swopped out coil packs
    New Sparkplugs
    Sprayed a whole can of Quicksilver Power Tune to dicarbon
    Cleaned Carbs
    any ideas will be appreciated
    here are some pics of the maiden voyage, after a 4year restoration project
ID:	427813Click image for larger version.
ID:	427814Click image for larger version.
    Feb 2014
    Missouri
    Don’t have the old books handy, but first guess is water pressure gauge tap.
    Dec 2001
    Very nice boat and background pixs..The back plate water is for PSI hookup. Them newer Merc got Pee water from top and bleed off steam. The running issue could be a hole in the fuel pump rubber or a Stator getting ready to go bad. Have you checked for good spark? Also pull the coils off and pull the rubber boot off and check for cracked carbon.... cracks weaken the field.
    May 2002
    Harriman, TN
    Water peeing on the spark plugs won't help the way it runs. Block that fitting and see if it helps.
  1. CLE on a 1983 Mercury 200
    By maineidyl in forum General Boating Discussion
    Last Post: 06-02-2017, 12:41 PM
  2. 1983 Mercury 115 HP inline six?
    By Brian B. in forum Technical Discussion
    Last Post: 03-13-2016, 01:14 AM
  3. 1983 32' velocity questions
    By biohzrd in forum General Boating Discussion
    Last Post: 11-14-2008, 07:01 PM
  4. (2) technical questions; Evinrude 235
    By Jeb1971 in forum Technical Discussion
    Last Post: 11-20-2007, 12:40 PM
  5. 1983 Mercury 80 HP inline
    By papermouth in forum Technical Discussion
    Last Post: 04-10-2007, 10:43 PM
