Page 9 of 9 FirstFirst 1 2 3 4 5 6 7 8 9
Results 121 to 135 of 135
Thread: 12' Cat Build
  1. #121
    Rhode Island
    Checkout dune buggy seats. Or forklift seats. They have cushion and are relatively simple.
    its looking great !
  2. #122
    Rhode Island
    Jan 2019
    Ontario Canada
    I think if I can find anywhere that I can get ahold of these they will fit nicely.
    Just wondering now how long I'll have to wait to go and test.
  4. #124
    Jan 2019
    Ontario Canada
    Modified the seat frames, I think I'll finish them and have someone do the upholstery. Click image for larger version.
ID:	463399Click image for larger version.
ID:	463400Click image for larger version.
  5. #125
    Jan 2019
    Ontario Canada
  6. Likes tnelsmn liked this post
  7. #126
    Jan 2019
    Ontario Canada
    So its loaded up, gathering tools and props.....only the 21p and 23p oem Johnson props. Nervous and excited at the same time. No seats yet but should be able to see how she floats and get some idea of what I'm dealing with......we will know by Saturday night one way or the other.
  8. Likes Jimboat liked this post
  9. #127
    Jan 2019
    Ontario Canada
    This is where I'm starting with engine height, still worried about water pressure.
  10. #128
    Looks like you will be ok. 1st ride is always a learning curve.
    Jun 2002
    Winter Haven Fl.
    Looks great, get a torque tab welded on that skeg if you plan on running the motor higher. Keep us posted.
  12. #130
    Jan 2019
    Ontario Canada
  13. Likes Jimboat, oldschoolltv, tnelsmn liked this post
  14. #131
    Jan 2019
    Ontario Canada
ID:	468078Click image for larger version.
    So I ended up having to raise the engine a lot, and it needs to go up still. I will need to remoove it from the plate and raise it there then start again.
    Was running a 21p stock Johnson prop.....
    1st run was 41 mph @ 4000rpm
    2nd run raised the engine 1" and ran 45 mph @ 4400rpm
    3rd run raised engine to upper limit of jack plate and ran 49mph@ 4900 rpm
    4th run added 75lbs of top soil to the bow and ran 52 mph @5100 rpm
    Water pressure still verry good and the boat is stable, so I think the 21p prop is in the ballpark just need one that will work better with this boat.
    There is a bit more speed in there I'm sure, going to move the fuel tank forward and go from there.
    I have some good pictures of the boat running but having trouble posting them at the moment......trying to figure it out now.
  15. #132
    Jan 2019
    Ontario Canada
  16. Likes oldschoolltv, 89LASER liked this post
  17. #133
    Running good, nice lil boat!
  18. Thanks Hoffer thanked for this post
  19. #134
    Jan 2019
    Ontario Canada
    Thanks, I am pretty happy with it. Still a lot more messing around to go.
  20. #135
    Jan 2019
    Ontario Canada
ID:	468306Click image for larger version.
    So I raised the motor up on the jack plate as high as it will go....for now.
    In the process of moving the fuel load forward as well.
    Could use some input on a better prop to try in the 21p range.
    The last run I posted the prop shaft was 2 1/4" below the lowest part of the sponson. Now it is even.....the jack plate is 6" set back, I dont have low water pickup.
  1. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  2. Mercury Tech: 2.5 build help
    By wfmarine in forum Technical Discussion
    Last Post: 04-18-2012, 10:43 PM
  3. If i were to build this 2.4 200.....
    By MidnightCarving in forum Technical Discussion
    Last Post: 03-20-2012, 07:04 AM
  4. 21' Build
    By mercracer2.5 in forum Fiberglass and Composites Discussion
    Last Post: 05-26-2011, 10:37 PM
  5. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
