Page 3 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 31 to 45 of 135
Thread: 12' Cat Build
  1. #31
    Rhode Island
    Quote Originally Posted by Hoffer View Post
    My bulkheads are 3/4" and I want to skin it with 1/4",
    Nice motor, would probably work really well on this boat.
    1/4" may be too thin, especially on flat surfaces. As soon as you give plywood a curve, it becomes MUCH stronger though. My front deck that has a curve, and the rear hatch behind the seat are like STUPID strong. No flex. But the tunnel bottom being flat under my feet flexes a bit when I stuff the tunnel. Nothing to concern me at all, but I can tell its bottoming out sometimes in rough water, or when going slow and it slaps, I can feel it flex.
    But yes, mine was 100% 1/2" plywood. African Okume mahogany marine ply. Bought from Boulter Marine in Massachusets.
    If you're interested in the 90hp I have, send me a private message.
  2. #32
    Jan 2019
    Ontario Canada
    I have some 1/2" as I was going that route originally, if I can find some help I will flip it this weekend and get the tunnel bottom skinned with 1/2". just worried about the bend at the nose,if it wont go maybe double 1/4" up front. As it sits the boat is very solid, that being said I will get a better feel when it comes off the jig.
    Maybe a little less thinking and more working now.
  3. #33
    Jan 2019
    Ontario Canada
  4. Likes home made tunnel liked this post
  5. #34
    Jan 2019
    Ontario Canada
    Tunnel bottom on today....
    Went with 3/8"
  6. Likes 89LASER liked this post
  7. #35
    Jan 2019
    Ontario Canada
ID:	429987Click image for larger version.
    Some more progres today.
  8. Likes W2F a V-King liked this post
  9. #36
    Jan 2019
    Ontario Canada
  10. Likes 89LASER liked this post
  11. #37
    Jan 2019
    Ontario Canada
  12. Likes W2F a V-King, 89LASER liked this post
  13. #38
    Aug 2015
    NE Tennessee
    Very Nice Work !!
  14. Thanks Hoffer thanked for this post
  15. #39
    Rhode Island
    Does it float yet ?!
  16. #40
    Jan 2019
    Ontario Canada
    Quote Originally Posted by home made tunnel View Post
    Probably would float if I toss it in the neighbours pool, not quite ready yet.
    I have to finish front sponson bottoms..... the 3/8 wont make the curve I am going for. I may have to use 1/4 and glass or sections of 3/8 and glass over,either way ill get there.
    Once the bottom is done the sides should be fairly straight forward. After the sides are on I will climb in and finish seal/paint the inside before installing the deck.
    Its coming along though.
  17. #41
    Jan 2019
    Ontario Canada
ID:	430733Click image for larger version.
  18. #42
    Jan 2019
    Ontario Canada
  19. #43
    Jan 2019
    Ontario Canada
  20. #44
    Rhode Island
    Is that a joint on the skin lapped, or is it just a butt joint? You've used a heck of a lot more hardware than I did haha. Is it All stainless?
  21. #45
    Jan 2019
    Ontario Canada
    Its joined to the bulkhead and but joined to the other skin, I tried a few times to use one piece.......lets just say it was an expensive lesson. All the hardware is stainless, need a lot to hold that 3/8" ply curve tight.
    I dont know how you pulled it off with 1/2".
    What did you use to water tight your hatch?
  1. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  2. Mercury Tech: 2.5 build help
    By wfmarine in forum Technical Discussion
    Last Post: 04-18-2012, 10:43 PM
  3. If i were to build this 2.4 200.....
    By MidnightCarving in forum Technical Discussion
    Last Post: 03-20-2012, 07:04 AM
  4. 21' Build
    By mercracer2.5 in forum Fiberglass and Composites Discussion
    Last Post: 05-26-2011, 10:37 PM
  5. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
