Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
    Jul 2013
    Corunna ontario
    Yes my sender is wet
  2. #17
ID:	427912Click image for larger version.
ID:	427913Click image for larger version.
    Welded a piece of angle in and drilled a dump hole behind it, plugged the dumps in the plate and drilled 1/8 drain holes in each pipe plug.
  3. Likes Forkin' Crazy liked this post
  4. #18
    Belgium
    Lyn, did this work for you? It did not for me. Engine temp was okay at speed but at idle I saw the temp dropping real quick. I closed all the little dumps. So only one big dump in the new cavity you welded. But than I drilled a hole in the water jnlet part in the adapter. The stock 2p plates have thiS too. This realy did the trick! I have a video of my boat running with the 2 pc adapter and filming my gauges. I compared this with a video with the 1 piece and it's about the same. I do have the cle with the bravo water pump base. This has the small weep hole. This might affect it too. I had the most trouble to retain some heat when at idle. If i idle around both t stats open after a while now. Never did without drilling in the inlet.
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  5. #19
    TX......somewhere?
    paul, if ya gonna use a skirt most all but you won't know its a 2 piece and all ya problems of, fab this, fab that, drill a hole here drill a hole there hopin' ya got it right, will all jus fad away...……… jmo.
  6. Likes tux974, FORBESAUTO liked this post
  7. #20
    Hey Tommy....since when have you enjoyed the simple and easier things in life...... I know as we get older.....
    JK...exactly my suggestion to him if he did not want to play or tweak things.......
  8. #21
    TX......somewhere?
    Quote Originally Posted by tux974 View Post
    since my depth perception, reflexes, strength all started goin' south 'bout eight years ago.... but we still "lookin' down at tha dirt" so all is good!
    although still understand tha thought process tha young-uns go through...………
  9. Likes tux974 liked this post
  10. #22
    NE Louisiana
    Thanks! I always wear my skirt. It is a part of Merc masculinity!!!
    Sounds like a plan to me. I have a 200 EFI and a real ProMax to play with too.
  11. #23
    TX......somewhere?
    think ya would be a lot safer with tha "stock coolin' junk" and have no worries if its all doin' what its supposed to.. jus add solid mounts on top.. bottom also if ya not runnin' tha off shore can...
  12. Likes Forkin' Crazy liked this post
  13. #24
    Quote Originally Posted by bigboy View Post
    Works fine..took an hour or so to weld, fit and clean up the dump passage, going back to the race cooling is easy, just take the dump plugs out.
  1. HI PERF> 1 piece exh. adaptor
    By billybob in forum Misc. Parts and Accessories
    Last Post: 10-10-2015, 08:24 PM
  2. Piston?? steel sleave? Need Help
    By sicknick12 in forum Technical Discussion
    Last Post: 04-19-2008, 07:17 PM
