Results 16 to 24 of 24
Thread: Steel sleave one piece adaptor
01-11-2019, 07:58 AM #165000 RPM
- Jul 2013
- Corunna ontario
- 116
- 9
- 27
Yes my sender is wet
01-11-2019, 10:15 PM #17
Forkin' Crazy liked this post
01-13-2019, 02:29 AM #18
Lyn, did this work for you? It did not for me. Engine temp was okay at speed but at idle I saw the temp dropping real quick. I closed all the little dumps. So only one big dump in the new cavity you welded. But than I drilled a hole in the water jnlet part in the adapter. The stock 2p plates have thiS too. This realy did the trick! I have a video of my boat running with the 2 pc adapter and filming my gauges. I compared this with a video with the 1 piece and it's about the same. I do have the cle with the bravo water pump base. This has the small weep hole. This might affect it too. I had the most trouble to retain some heat when at idle. If i idle around both t stats open after a while now. Never did without drilling in the inlet.
01-14-2019, 05:27 AM #19
paul, if ya gonna use a skirt most all but you won't know its a 2 piece and all ya problems of, fab this, fab that, drill a hole here drill a hole there hopin' ya got it right, will all jus fad away...……… jmo.
tux974, FORBESAUTO liked this post
01-14-2019, 05:45 AM #20
Hey Tommy....since when have you enjoyed the simple and easier things in life...... I know as we get older.....
JK...exactly my suggestion to him if he did not want to play or tweak things.......
01-14-2019, 05:53 AM #21
tux974 liked this post
01-17-2019, 01:01 AM #22
01-17-2019, 01:16 AM #23
think ya would be a lot safer with tha "stock coolin' junk" and have no worries if its all doin' what its supposed to.. jus add solid mounts on top.. bottom also if ya not runnin' tha off shore can...
01-17-2019, 02:07 AM #24
HI PERF> 1 piece exh. adaptor
By billybob in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-10-2015, 08:24 PM -
Piston?? steel sleave? Need Help
By sicknick12 in forum Technical DiscussionReplies: 4Last Post: 04-19-2008, 07:17 PM
