Results 1 to 5 of 5
01-08-2019, 05:45 AM #16000 RPM
- Loudon Tn
- 1,430
- 7
- 59
can't bleed trim ant tilt little help please
trim and tilt stopped working. the plastic relief valve head broken. I drilled plastic out as best I could and used dap to clean out threads. Put in stainless bolt in place of nylon plug. Replaced both relays but ended up replacing motor. All went well and motor runs fine but I can not get the hydraulic to bleed. The unit is a 1999 pro max style. Two arm two wire unit that is located between the clamp (not remote). Anyone have any idea how to bleed this unit? Thanks in advance for any assistance guys.
have fun be safe
01-08-2019, 06:37 AM #26000 RPM
- Loudon Tn
- 1,430
- 7
- 59
01-08-2019, 07:33 AM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
The plastic relief valve is long and has 3 or so O rings to direct the oil... a SS bolt has a flat end..... not telling the oil where to go.... Most drill jobs mess the O ring seats...
01-08-2019, 08:51 AM #46000 RPM
- Loudon Tn
- 1,430
- 7
- 59
trim
Crap didn't know that. Thanks for info
01-08-2019, 10:45 PM #55000 RPM
- Oct 2008
- Plainville, CT
- 804
- 417
- 377
- 67
I had a devil of a time getting an old plastic relief valve out of mine. Tried a few different methods; one of them drilling it out. I messed it up. The valves are kind of expensive, but if you didn't mess up the unit drilling it then a new relief valve may allow it to work again.
I luckily ended up getting a whole (used) unit in good shape for a pretty good price, but was not happy about messing up that unit.
Tilt N Trim won't Tilt N Trim on 2006 Tohatsu MD 50 B
By ZO6 in forum Technical DiscussionReplies: 12Last Post: 12-31-2018, 09:29 PM -
Aftermarket trim: Panther power trim and tilt bracket opinions?
By mxz in forum General Boating DiscussionReplies: 4Last Post: 10-28-2016, 06:05 AM -
bleed'n out single ram trim help
By sk844 in forum Technical DiscussionReplies: 9Last Post: 04-03-2015, 09:46 AM -
How much trim bleed down is acceptable?
By 1fast68 in forum Technical DiscussionReplies: 7Last Post: 01-04-2008, 12:39 AM -
How to bleed trim?
By trubornot in forum Technical DiscussionReplies: 4Last Post: 05-09-2005, 05:27 PM
