Results 16 to 19 of 19
Thread: 3.0 running rough at idle
01-14-2019, 10:17 AM #167000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
I don't run without the air box at the moment. Ill have to run it at idle without it on and see if its spitting fuel out the carb.
01-14-2019, 10:34 AM #175000 RPM
- Oct 2017
- Hugo, MN
- 326
- 36
- 18
- 62
- 81
It's just one opinion. Mine intermittently sneezes, but even when not sneezing it is pushing air and air/fuel back OUT the carb throat.
So I think a damaged reed is allowing the air back out. The air and sneeze started at the same time and are on the same carb.
But I'm no expert.
01-14-2019, 12:19 PM #187000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ill have to lo into it more, but it could be reeds. I believe there are aftermarket reeds in it.
01-14-2019, 06:29 PM #195000 RPM
- Sep 2011
- Deplorableville
- 740
- 1281
- 76
- 3144
- 1452
If you have a manual, do the link and sync procedure EXACTLY as the book says. My old 225 looper idled like that until I followed the instructions fully. It would then idle perfectly for quite a while after that.
Instigator liked this post
Mercury Tech: 2.5 rough idle
By redsnapper386 in forum Technical DiscussionReplies: 5Last Post: 02-22-2018, 10:26 AM -
Mercury Tech: -85 200 2.4 rough idle, stumble, extreme fuel consumption, cold idle
By Roos in forum Technical DiscussionReplies: 11Last Post: 08-11-2014, 06:21 AM -
1973 evinrude 85 is running rough at idle speed in gear.
By Palmtreeguy in forum Technical DiscussionReplies: 6Last Post: 06-06-2012, 12:40 AM -
2.5 260 rough idle
By YELLOWSS in forum Technical DiscussionReplies: 0Last Post: 08-04-2005, 08:05 PM
