Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
    Mar 2009
    Port Saint Lucie
    I don't run without the air box at the moment. Ill have to run it at idle without it on and see if its spitting fuel out the carb.
  2. #17
    Oct 2017
    Hugo, MN
    Quote Originally Posted by Gorilla0178 View Post
    It's just one opinion. Mine intermittently sneezes, but even when not sneezing it is pushing air and air/fuel back OUT the carb throat.
    So I think a damaged reed is allowing the air back out. The air and sneeze started at the same time and are on the same carb.
    But I'm no expert.
  3. #18
    Mar 2009
    Port Saint Lucie
    Ill have to lo into it more, but it could be reeds. I believe there are aftermarket reeds in it.
  4. #19
    Sep 2011
    greensboro, nc
    If you have a manual, do the link and sync procedure EXACTLY as the book says. My old 225 looper idled like that until I followed the instructions fully. It would then idle perfectly for quite a while after that.
  5. Likes Instigator liked this post
  1. Mercury Tech: 2.5 rough idle
    By redsnapper386 in forum Technical Discussion
    Last Post: 02-22-2018, 10:26 AM
  2. Mercury Tech: -85 200 2.4 rough idle, stumble, extreme fuel consumption, cold idle
    By Roos in forum Technical Discussion
    Last Post: 08-11-2014, 06:21 AM
  3. 1973 evinrude 85 is running rough at idle speed in gear.
    By Palmtreeguy in forum Technical Discussion
    Last Post: 06-06-2012, 12:40 AM
  4. 2.5 260 rough idle
    By YELLOWSS in forum Technical Discussion
    Last Post: 08-04-2005, 08:05 PM
