Results 1 to 5 of 5
Thread: Merc 5L Alpha upper failure
01-02-2019, 05:18 PM #1
Hey fellas, happy new year!
My first time venturing into the sterndrive forum is for a buddy of mine who's Alpha 1 Gen 2 upper lunched itself the other day (Bayliner 5L Merc). Would really appreciate a bit of advice if anyone could chime in. It's 24t/24t upper and 1.6x:1 lower. Lower seems otherwise in good shape other than maybe ingesting some filings from the upper - freshwater boat.
Options are:
1) get a new (SEI?) aftermarket upper for about $2400NZ (I see they're more like $1300NZ on Ebay, but problem is getting it here, shipping and border tax etc)
2) get a complete secondhand Merc sterndrive (off a 4cyl boat) locally for about $1300NZ (will pop the top off to make sure the upper is in good shape and is also 24/24 tooth first). And sell the 2:1 lower to recoup some costs. If this upper is 24/24tooth, is it safe to assume it's otherwise identical to the stock v8 upper?
Would appreciate any input from those of you in here that really know these drives - coz we don't!
Cheers
Gene
01-02-2019, 11:47 PM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,097
- 1008
- 354
- 4297
- 1951
- 7 Post(s)
you need to pull the lower apart as well, as all that crap has gone down into it
gmacrae thanked for this postbaja200merk, gmacrae liked this post
01-03-2019, 06:08 AM #3
01-03-2019, 08:49 PM #4
Good advice, thanks guys - looks like the complete 4cyl lower is the way to go - contacted the guy and we should have it next few days
01-12-2020, 05:24 AM #5Junior Member
- Jan 2020
- Australia
A 4 cyl upper is going to have different gearing to your V8 one. In an alpha all the lowers are the same ratio, the uppers are where the ratios change.
Edit - from memory the 5.0 has 1.5 or 1.6 to 1, the 4 cyl has 2 to 1.
Also edit - damn just saw this post is a year old, I'm sure you've already figured all this outLast edited by Bremdanm; 01-12-2020 at 05:27 AM.
Anybody know if a alpha 1 gen 1 lower will bolt to and mc 1 upper
By delawarerick in forum Technical DiscussionReplies: 7Last Post: 05-10-2013, 06:09 PM -
Mercury Tech: Repairing a alpha one gen 2 upper??
By strehl in forum Technical DiscussionReplies: 0Last Post: 06-10-2011, 07:46 PM -
Alpha One Flywheel Coupling Failure?
By john j 80 viking in forum Technical DiscussionReplies: 6Last Post: 04-22-2010, 08:50 PM -
Help!, Omc Upper Bearing Failure.
By MrCougar in forum Technical DiscussionReplies: 9Last Post: 01-03-2002, 09:14 AM
