Results 1 to 5 of 5
    Jan 2010
    Rotorua, NZ
    Merc 5L Alpha upper failure
    Hey fellas, happy new year!
    My first time venturing into the sterndrive forum is for a buddy of mine who's Alpha 1 Gen 2 upper lunched itself the other day (Bayliner 5L Merc). Would really appreciate a bit of advice if anyone could chime in. It's 24t/24t upper and 1.6x:1 lower. Lower seems otherwise in good shape other than maybe ingesting some filings from the upper - freshwater boat.
    Options are:
    1) get a new (SEI?) aftermarket upper for about $2400NZ (I see they're more like $1300NZ on Ebay, but problem is getting it here, shipping and border tax etc)
    2) get a complete secondhand Merc sterndrive (off a 4cyl boat) locally for about $1300NZ (will pop the top off to make sure the upper is in good shape and is also 24/24 tooth first). And sell the 2:1 lower to recoup some costs. If this upper is 24/24tooth, is it safe to assume it's otherwise identical to the stock v8 upper?
    Would appreciate any input from those of you in here that really know these drives - coz we don't!
    Cheers
    Gene
    8 Post(s)
    you need to pull the lower apart as well, as all that crap has gone down into it
  3. Thanks gmacrae thanked for this post
    Likes baja200merk, gmacrae liked this post
    I would find a factory upper that has low hours or easy life behind a 4 cyl before I got an SEI. Thats saying something because they are 20 mins away from me not on the other side of the world
  5. Thanks gmacrae thanked for this post
    Likes gmacrae liked this post
    Jan 2010
    Rotorua, NZ
    Good advice, thanks guys - looks like the complete 4cyl lower is the way to go - contacted the guy and we should have it next few days
    Jan 2020
    Australia
    A 4 cyl upper is going to have different gearing to your V8 one. In an alpha all the lowers are the same ratio, the uppers are where the ratios change.
    Edit - from memory the 5.0 has 1.5 or 1.6 to 1, the 4 cyl has 2 to 1.
    Also edit - damn just saw this post is a year old, I'm sure you've already figured all this out
  1. Anybody know if a alpha 1 gen 1 lower will bolt to and mc 1 upper
    By delawarerick in forum Technical Discussion
    Last Post: 05-10-2013, 06:09 PM
  2. Mercury Tech: Repairing a alpha one gen 2 upper??
    By strehl in forum Technical Discussion
    Last Post: 06-10-2011, 07:46 PM
  3. Alpha One Flywheel Coupling Failure?
    By john j 80 viking in forum Technical Discussion
    Last Post: 04-22-2010, 08:50 PM
  4. Help!, Omc Upper Bearing Failure.
    By MrCougar in forum Technical Discussion
    Last Post: 01-03-2002, 09:14 AM
