Results 1 to 4 of 4
    Dec 2018
    Provo, Utah
    Fiberglass bubble on floor - could you help
    There is a 6 x 14 bubble in the fiberglass floor. The fiberglass is over 3/4 in plywood. The plywood is in good shape. There is a very thin layer of glass on top from the cloth. Do I just grind it out and then patch with cloth resin/hardner. Or do I just drill one or two holes in the top of the bubble and fill it with epoxy?
    There are no other bubbles. There was an inch hole. I could see the plywood. There it looked good and the floor is strong or hard all over. What would you suggest?
    Thank you in advance.
    Just grind it out and patch. I suspect that you will find more extensive delamination than you see now when you open it up.
    Gravenhurst, Ontario.
    What kind of plywood?
    Rhode Island
    If you're good with epoxy - take the whole piece out with a razor knife / box cutter. sand both the cloth and boat, slab on some thickened epoxy, put it back down, and put something flat with weight on it. Some wax paper to prevent your weights from sticking helps.
    But after you pull it up, you'll see if there's any other issues.
  1. Challenger 21 superboat Fiberglass interior floor?...
    By pdr1966 in forum General Boating Discussion
    Last Post: 05-04-2015, 06:51 PM
  2. Seeking Info on removing Fiberglass Floor HydroStream
    By SOUTHTEXASHYDROSTREAM in forum Fiberglass and Composites Discussion
    Last Post: 02-13-2015, 09:34 AM
  3. Redoing floor/ drop floor
    By gmjim in forum Fiberglass and Composites Discussion
    Last Post: 08-09-2013, 07:58 AM
  4. In floor heat and a in floor fish tank.
    By JrCRXHF in forum The Scream And Fly Lounge
    Last Post: 01-08-2010, 01:33 PM
