Results 1 to 8 of 8
    Valrico Fl.
    Hub a V-4 OMC Raker for a v-4 Yama ?..
    what prop shop can rehub a OMC Raker to work on a new 4 cylinder Yamaha . Thanks for any help . Prop is in SC . Thanks for any help .
    Valrico Fl.
    Quote Originally Posted by Dingie 2 View Post
    140 view and nobody has had a v-4 Raker rehabbed to fit a v-4=Yamaha . I was hoping that someone has had this done and knew a shop that we could send this prop to . I have several e mails out to shops asking if they have ever done a modification or rehab that works well . I have seen OMC props on Yamaha but have not found any shop that has done this with good results if anyone has had this done ai would really appreciate the info . Joe R
    Sep 2016
    McHenry,Illinois
    I have a Raker for my 1975 135 Evinrude but have never looked at the hub size vs the Yammie...not sure if there is a difference between the newer and older OMC V4 hubs ...will try to check next week when I get back to the shop...maybe someone will chime in sooner. If its a std hub any prop shop can press in a new hub with Yammie splines. Have you checked with your local prop shops?
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork (Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Ranger 17' Aztec / Merc 115
    Hustler 16' Victor
    Hustler 16' Victor / JohnRude 135 (current and restored)
    Hustler 15' Family Tunnel / Johnson GT115 (current project)
    Hustler 16' Victor
    Sep 2016
    McHenry,Illinois
    Sorry...I didn't read your post all the way thru....What Raker do you have now...which OMC v4 does it fit and what Yamaha are you trying to make it fit...I can call my local prop guy to find out ( he does lots of hi-pro prop work).
    Hustler 16' Victor
    Hustler 16' Victor
    Valrico Fl.
    Quote Originally Posted by DanUmbarger View Post
    This is on the box Raker V-4 PN 0763954 3X13 1/2 X 20 R , he want to install it on a 2017 VF115 Yamaha 4 cylinder . The Rsker is A 13 spline , the Yamaha is a 15 spline . Thanks for the help .
    Jan 2015
    This guy is local to me and can install a new hub for you.
    http://tbpropeller.com/index.php
    I googled propeller repair shops, no location in general, and came up with this, a little closer to you. Also installs new hubs. Good luck.
    http://www.danspropshop.com/contactus.php
    Valrico Fl.
    Quote Originally Posted by SS Minnow View Post
    This isn’t s normal rehab it is removing a 12 spline OMC rubber press in hub and installing a 15 spline Yamaha hud . He wants to send it to a shop that has already done the conversion . We have talked to a few shops but not found one that has done the conversation and knows what we will need to install the OMC Raker v-4 prop on the VF 115 Yamaha . A couple shops said that they Yamaha hub presses in from the opposite side of the OMC . We have seen people run these props on Yamaha 115 but have no idea who did the work . Again thanks for any help .
    Valrico Fl.
    SS Minnow , Thanks I contacted Dan at danspropshop and he has done this modification to a OMC Raker before . Thanks again for your time and help . There is a lot more to this than just pressing a yamaha hub in a OMC prop it’s over a two hundred dollar job .
    Dingie 2
  1. Raker props -> Raker vs Raker II
    By MarkOliver in forum Props, Setup, and Rigging
    Last Post: 09-02-2012, 09:12 PM
  2. OMC Tech: What's the difference Raker & Raker II? Prop
    By decoy033 in forum Technical Discussion
    Last Post: 05-17-2010, 04:30 AM
  3. OMC Tech: Whats the difference between raker and raker II props
    By antonietti in forum Technical Discussion
    Last Post: 12-28-2008, 10:46 AM
