Results 1 to 3 of 3
12-28-2018, 06:39 PM #1
3 cylinder evinrude 25 hp electrical issues?
Looking for anyone that might have some tips on this one, it is the 3 cylinder Ec model evinrude 25 hp, went fishing today motor cranked up ran great then all of the sudden it shut off no spark, I had this happen before and thought it was a ground issue so I added an extra ground for the pack and used it with no problems for a few outings I disconnected the kill wire to make sure it wasn’t a wire harness issue still no spark, I decided to troll around and fish for a while then tried it again and it cranked and ran great the rest of the day, loaded it up drove home about an hour and a half got home battery stone dead, put a charger on it to crank it to flush salt water out and checked across the battery terminals only 12.5 volts. I am trying to see if I have two problems like pack and reg/rectifier or stator and reg/rectifier or could it just be one of them causing both problems no spark intermittent and no charge/drain, I have the oem manual and will look at it next week but hoped for some advise, also I no longer have a peak voltage meter only std. multimeter, thanks Matt.
01-01-2019, 09:42 AM #2Junior Member
- Mar 2016
- marquette mi. 49855
- 20
Work backwards Charge battery remove one + wire at a time to find the draw/ drain. Disconnect and test for a c voltage before the D C voltage regulator. Not sure if Evenrude has trigger coil like the Mercs.By adding the ground at first you moved something ? Because it didn't work! If all cylinders cut out you would think it's no power going in or the pack getting hot typing on my phone sucks good luck
01-01-2019, 03:38 PM #3
I took a quick look today and am going to order a peak voltage adapter, I miss having one as they are so useful. Thanks
1988 Mercury 90hp 3 cylinder issues
By gunguy419 in forum Technical DiscussionReplies: 5Last Post: 04-26-2017, 01:05 PM -
OMC 70hp 3 Cylinder Deadman Issues
By hoodooguru in forum Technical DiscussionReplies: 1Last Post: 11-06-2012, 02:00 PM -
1993 245 w/ cylinder bore issues
By mrcrsr in forum Technical DiscussionReplies: 6Last Post: 11-04-2007, 10:11 AM -
Electrical problem, loss of spark to cylinder 4
By Hydraulica in forum Props, Setup, and RiggingReplies: 2Last Post: 01-19-2007, 08:39 PM -
2.5 EFI SS electrical issues
By Toffen in forum Technical DiscussionReplies: 3Last Post: 07-15-2006, 11:38 PM
