Results 1 to 6 of 6
    Jun 2017
    Houston
    WTB Coned Washer
    I'm wanting to set my prop back as far as I can on a mercury sportsmaster. Does anyone have a coned washer that can accommodate my needs
    Pekin, IL
    I assume you are talking about a thrust washer in which case why not just put a washer with a straight bore (you will be past taper with stock thrust washer) tween the thrust washer and prop. Easily made by any machine shop exactly the dimension your needs require.
    Rock
    Team Junk
    Jun 2017
    Houston
    Good point... why didn't I think of that
    Dec 2001
    You want MORE stress on the prop shaft ?
    Jun 2017
    Houston
    Not on a full time, just something for the top end runs, I have a goal of 120 this season... gotta go faster
    Dec 2001
    The tapper on the washer is close to where the propshaft is weak......Like on on the a car.... the inner bearing takes the hoz load,,,,, the outer just keeps the wheel from falling off. Put offset wheels on and it puts more stress on the inner as the contact patch is moved past the inner bearing......On a car you want the tire center to line up with the load center/ball joints or crazy steering with too much off set.Car stuff....Looking for more speed I understand .... but breaking PS or prop blades is risky.... If you have Fat shaft pay no heed to what I a saying.....
  1. Looking for a coned 2.5 l/u.
    By dlivewyer in forum Lower Units
    Last Post: 09-05-2018, 08:43 PM
  2. Coned 187 cle
    By jjamieson7284 in forum Lower Units
    Last Post: 02-17-2016, 08:19 PM
  3. XR 4 coned
    By Varmint in forum Lower Units
    Last Post: 05-11-2014, 06:29 PM
