Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 55 of 55
  1. #46
    Sep 2017
    Ashland city tn
    Usually when exhaust ports r raised then most like to add little compression to make up for bottom end loss and makes for a great powerband
  2. Thanks HaulNbass thanked for this post
    Likes HaulNbass liked this post
  3. #47
    Jul 2018
    Smyrna GA.
    Thank you for advice much appreciated, blew my 225 up in tournament this past weekend (rod smashed hole in block). Now trying to decide witch motor to put on boat,have an 1981 Johnson 150, and a 1985 Johnson 140-v4. Any suggestions? Also need a v-6 looper powerhead to go on my 1990 mid section if anyone is selling one around Georgia. Thank everyone for advice and suggestions. Enjoy Safe happy screaming&flying peace I’m out!��
  4. #48
    Sep 2017
    Ashland city tn
    Quote Originally Posted by HaulNbass View Post
    Stick 150 on and run till u can get what u want together
  5. Thanks HaulNbass thanked for this post
  6. #49
    Jul 2005
    AZ
    You've got a pm
    Good luck
    '84 Checkmate Convincor
  7. Thanks HaulNbass thanked for this post
  8. #50
    Jul 2018
    Smyrna GA.
    What is highest rpm’s you can spin an 81,omc,150. Is it safe to surface a chopper with this engine. Only has exhaust relievers opened up and exhaust holes (can plug) drilled in lower unit. Want to put some pull over carbs on and set timing back from 28 to 24. Thank’s everyone, happy safe screaming and flying, love that checkmate!!
  9. #51
    Apr 2016
    Port perry
    Ok guys been a while I've been working on it slowly but surely. So I've got it all back together I put my air box, carbs butterfly's and reeds and reed cage from my 89 225 looper on to my 95 vindicator 200 which I have done the exhaust port work too. Now the issue I'm running into is I dont have the wiring harness that goes from the controls on the boat to the motor for the 95 vindicator but the wiring harness from my 89 225 looper is still installed in the boat both of which are the big red plug. I'm wounded if anyone knows if i can make this work these are the wires i have on the motor and on the boat.Click image for larger version.
ID:	444094Click image for larger version.
  10. #52
    Jan 2015
    Schematics from both is where I would start. Need to know what each wire is for.
  11. #53
    Apr 2016
    Port perry
ID:	444130 I can only find the 89 225 diagram does anyone know were I can get a 95 200 vindicator diagram.
  12. #54
    Jul 2005
    AZ
    Quote Originally Posted by 91 charger stv View Post
ID:	444131Click image for larger version.
  13. #55
    Apr 2016
    Port perry
    So after reviewing the drawings the red plug is 90 percent the same from motor to motor but there are 2 difference that I can tell one of which is the vro plug but I have deleted the vro so that shouldn't matter. The other is the tan wire in the motor I'm putting on the boat "95" is going to a vacuum switch and temp sensors and on the 89 motor that I'm trying to use the controller wires from go to a cut off switch and temp sensors so I need to know if the vacuum switch and cut off switch are one in the same. Thanks for the help
  1. OMC 2 L porting
    By evilrude 1 in forum Technical Discussion
    Last Post: 02-22-2014, 08:50 PM
  2. Replies: 11
    Last Post: 06-13-2010, 02:03 PM
  3. XR4 porting?
    By peedeerooster in forum Technical Discussion
    Last Post: 11-11-2008, 09:27 PM
  4. Evinrude Porting
    By BilDewey in forum Technical Discussion
    Last Post: 10-06-2001, 09:18 AM
  5. Question on Z porting VS. Bridge porting?
    By Riverracer280SS in forum General Boating Discussion
    Last Post: 09-05-2001, 08:52 AM
