Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 55
    Sep 2017
    Ashland city tn
  2. Likes HaulNbass liked this post
  3. #17
    Sep 2017
    Ashland city tn
    If u zoom in u can see a very small bevel/chamfer around ea port , it's the shiny part of port, helps from ring snag and kinda acts like port is opening little sooner, I very very reputable builder did mine , dont go over board tho just get rid of sharp edge
  4. Likes HaulNbass liked this post
  5. #18
    Apr 2016
    Port perry
    Ok I get what your saying were I grinded I beveled it but I see what u mean bevel it in the corners more then it is so the ring doesn't catch
  6. #19
    Sep 2017
    Ashland city tn
    Exactly. Just doin all way around port so no snag up or down
  7. Likes HaulNbass liked this post
  8. #20
    Apr 2016
    Port perry
    So other than beveling the edges so the rings dont catch is there anything else I should do to get more horse power out of this motor.
  9. #21
    Sep 2017
    Ashland city tn
    Gonna let sumone more experienced comment on that
  10. #22
    May 2014
    Livingston, Louisiana
    I’m not real familiar with that mota, so take this with a grain of salt, this is in generic terms. Maybe an OMC guru like racer will step in. On your champhered edges do get too crazy with it to point where it changes the trajectory. On the long transfer ports you want the short side toward exhaust to have just enough to not snag ring, same with the long top side, short side toward booster ports will be laid over pretty good. This helps prevent short circuiting and aid in loop flow up to spark plug. Without changing port timing drastically you can increase the top angle (or a little more beveling) a little on booster ports to give a little more top end power.
  11. #23
    May 2014
    When you bevel the ports for the rings, you are mainly just touching up near the surface. If you cut it the the thickness of the sleeve, you are now messing with the port angles and need to be careful doing that, being that can change the characteristics of the ports, either for the good or for the bad. Hopefully that makes a little sense.
  12. #24
    Jul 2005
    AZ
    95 done by the man himself. This is what you want it to like
    hope they are helpful..tried to get the best ones but pics are a mess
ID:	429883Click image for larger version.
ID:	429884Click image for larger version.
ID:	429885Click image for larger version.
ID:	429891Click image for larger version.
ID:	429892Click image for larger version.
ID:	429888Click image for larger version.
ID:	429889Click image for larger version.
ID:	429890Click image for larger version.
ID:	429887Click image for larger version.
    '84 Checkmate Convincor
  13. Likes FMP, sharpeye Mike, HaulNbass liked this post
  14. #25
    Apr 2016
    Port perry
ID:	430731 ok guys got the exhaust ports done and all the casting seams and slag knocked down I'm just waiting for the gasket kit to come in so a couple of questions first thing is normally after a rebuild I would pressure wash the engine block to get all the shaving out but I live in Canada and it is igloo season so I cant use my pressure washer does anyone have any other ideas on how to clean it out. Also is there a point in me blocking the exhaust relive holes I have read a couple of things on here about it just not sure if it's worth the risk of the epoxy coming out and going throw my motor. And is there anything else anyone can think of to get more out of the motor internally before I put it back together. Thanks
  15. #26
    Sep 2017
    Ashland city tn
    If u has big jug of paint thinner or wd 40, can use that but after initial cleaning,I put mine n bathtub while wife was gone lol,
  16. #27
    Apr 2016
    Port perry
    That's not a bad idea I like causing trouble so I could throw it in the tube right before shes going to have a shower lmao
  17. Likes Merc 2.5 liked this post
  18. #28
    Jul 2005
    AZ
    [QUOTE=91 charger stv;3111904]That's not a bad idea I like causing trouble so I could throw it in the tube right before shes going to have a shower lmao[/QUOTE
    Yes throw it in before she gets in so she can save water and clean it while she's in there..then jump in and finish cleaning it ..water saving
  19. #29
    lindsay on. canada
    coin wash …………………...
  20. #30
    Apr 2016
    Port perry
    Ya that's what I was planning on doing just wasnt sure if there was some secret someone knew I guess ill bring a jug of oil to spray in the cylinders and crank housing
  1. OMC 2 L porting
    By evilrude 1 in forum Technical Discussion
    Last Post: 02-22-2014, 08:50 PM
  2. Replies: 11
    Last Post: 06-13-2010, 02:03 PM
  3. XR4 porting?
    By peedeerooster in forum Technical Discussion
    Last Post: 11-11-2008, 09:27 PM
  4. Evinrude Porting
    By BilDewey in forum Technical Discussion
    Last Post: 10-06-2001, 09:18 AM
  5. Question on Z porting VS. Bridge porting?
    By Riverracer280SS in forum General Boating Discussion
    Last Post: 09-05-2001, 08:52 AM
