Results 31 to 45 of 55
  1. #31
    Apr 2016
    Port perry
ID:	433871 hey guys finally got my gasket kit in getting ready for reassembly but last night I found these heads that are al stoker (racer) was wondering if they would benefit my motor.
  2. #32
    Jul 2005
    AZ
    Definitely...!! What boat are you running it on?
    '84 Checkmate Convincor
  3. #33
    Apr 2016
    Port perry
    20 foot charger tv it's a modified vee hull.Does 82mph with the 89 evinrude 225 and a 28pitch raker Click image for larger version.
  4. #34
    Jul 2005
    AZ
    Thought so from the name..
  5. #35
    Sep 2017
    Ashland city tn
    U got motor assembled yet?
  6. #36
    Apr 2016
    Port perry
    No not yet going to clean up the garage today and start building tomorrow.
  7. #37
    Jul 2005
    AZ
    You do anything else that would raise compression?
  8. #38
    Apr 2016
    Port perry
    No I'm going to leave the exhaust relief holes open. I dont want to run anymore the 91 octane as it's not that easy to find much over that.
  9. #39
    Jul 2018
    Smyrna GA.
    Are there any books out there on porting v-6 omc’s, and who is the best porter on OMC’s,. Heard about monty, anyone in GA. Maybe?
  10. #40
    Jul 2005
    AZ
    Quote Originally Posted by HaulNbass View Post
    James Perry in Tennessee..does great work he did my motors
  11. Thanks HaulNbass thanked for this post
    Likes HaulNbass liked this post
  12. #41
    Feb 2014
    Missouri
    One trick I learned was oil them down with the oil you will use during use after the build and it’s running.
    After port work not much left.
    Reeds and stuffers can can play with them seeing how the reed material adjust reed timing and gives the best crank fill. Stuffers can increase flow.
    Spacer height to adjust case fill velocity which packs more in the case.
    You can can also do some exhaust stuff. But factory is pretty good. Drag vent (ofshore cutout ect).
  13. Thanks HaulNbass thanked for this post
  14. #42
    Apr 2016
    Port perry
    Ok guys it's taken me way longer then I wanted but I got the pistons in and connecting caps aligned and torqued down and I'll be working on it all day today but one thing I'm wondering is jet sizing now that I've done this port work?
  15. #43
    Jan 2015
    Yeah, them little things are expensive. And I only have to buy sets of 4.
  16. #44
    Sep 2017
    Ashland city tn
    I guess b4 1 starts attempting a educated guess he would need to know exactly what all was done to mota , would def help ,, maybe racer will see it , the omc guru
  17. #45
    Apr 2016
    Port perry
    The only thing done is the exhaust porting.
  1. OMC 2 L porting
    By evilrude 1 in forum Technical Discussion
    Last Post: 02-22-2014, 08:50 PM
  2. Replies: 11
    Last Post: 06-13-2010, 02:03 PM
  3. XR4 porting?
    By peedeerooster in forum Technical Discussion
    Last Post: 11-11-2008, 09:27 PM
  4. Evinrude Porting
    By BilDewey in forum Technical Discussion
    Last Post: 10-06-2001, 09:18 AM
  5. Question on Z porting VS. Bridge porting?
    By Riverracer280SS in forum General Boating Discussion
    Last Post: 09-05-2001, 08:52 AM
