Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: 40 amp flywheel
    Feb 2012
    Raceland Louisiana
    40 amp flywheel
    Did mercury make a light weight 40 amp (red) flywheel for a 2000 model 225 promax?
    Sep 2017
    Ashland city tn
    U mite b abke to get it cut on but I really doubt it. Not really sure but no lite weights stock. This is also comin from someone that's never ran a 40. I always say do away with it unless GOTTA have it
    Yes I think they did the red one , dunno how much lighter they were than the black one , I have one around here somewhere ( Maybe )
    Jay
    Jay @ JSRE
    Sep 2017
    Ashland city tn
    Chit well there ya go. Jay the man!!
    Sep 2017
    Ashland city tn
    Hey jay. Thought u was sending me out sum jsre stickers? Getcha sum more advertisement out there!!
    I asked you to send me your address, EMail me it to :
    hitman6563@yahoo.com
    and I’ll head them your way
    Jay @ JSRE
    Sep 2017
    Ashland city tn
    Sent. Thanks jay!!
    Jul 2002
    FT WORTH, TEXAS
    guy named Dunn made some a while back they wuz 900 and some change i bought one magnets were in wrong location sent it back they were going to fix it send it back to me never did sent my money back instead !!!!it had how ever same magnet layout and magnet surface area of 16 amp flywheel magnets though so dont know where it went from there? do your home work goog luck
  9. Likes tux974 liked this post
  10. #9
    TX......somewhere?
    first coupla year of 40's were red and a "flex plate" type.. justa tad lighter but not enough ta mater much.... nothin' else by merc.
  11. Likes tux974 liked this post
    Never seen a PM come with a red flywheel especially a 2000. They were black cast iron.
    Red flywheels with bigger magnets like the black cast iron were in 80's 40amp system if I remember correctly.
    Like mentioned above they were not much lighter and only small advantage was the flex plate. What I also found a down side was the cooling, not enough holes for venting to properly cool with higher rpms.
    Also as mentioned J Dunn did make some but had issues not sure he is still making them.
    Brendan Powers was making some real nice ones, not sure he got them completed, he was close and testing. Have not spoken to him lately.
    These 2 below I swapped out I while ago.
  13. Likes Frank Molé, texasvector liked this post
  14. #11
    Sep 2017
    Ashland city tn
    I had just got rid of a red one few days ago and it was heavy, cant imagine the black one being much heavier, dnt believe u would ever know the difference.
    It was not much but yes a bit. Mercury just did not expect/recommend to spin them above 7000 like many of us do to the 225Promax.
    If that cast iron is out of balance in anyway it really hurts the upper crank bearing longevity.
  16. #13
    Sep 2017
    Ashland city tn
    So is the 16amp just not sufficient for the PM? I know I've seen few 16s on PM but may have had vst delete , so will 16 run stock PM if your not runnin bunch of graphs and stuff?
  17. #14
    Yep but you’ll have to change stator and the rear voltage regulators to a rectifier system , the 16 high performance system have a limited battery charge capacity.
    Jay
    Jay @ JSRE
  18. #15
    Yes, it is sufficient enough as long as you do not run lots of electrics. many of us run 16amp wether it is a stock OEM or some proven after market flywheel.
    Like mentioned above you will need to change some electrics and wiring, not hard to do to properly setup the 16amp system.
    It can be done a few ways. Best advise I can personally give you and what I have found that copying the 245/260 setup has worked well for me.
    I personally run 16amp on my own setups but like to plug the tender on when sitting home because it will sit a couple of weeks at a time to keep things up to par. Everyone has their own opinion on how to best do it.
  19. Likes Frank Molé, W2F a V-King liked this post
  1. OMC 225 HP flywheel
    By cmn in forum Technical Discussion
    Last Post: 05-11-2008, 10:25 AM
