Results 16 to 30 of 34
Thread: 40 amp flywheel
12-22-2018, 10:04 AM #16
JAN... I got away with no regulator with tha 16 stuff (BP's, OP's, 245's, 260's, OS tnt) for very long time way back when.. jus used very good batteries with good maintance on 'em.. fishing boats with normal junk on 'em..
12-22-2018, 07:07 PM #17
12-22-2018, 08:30 PM #18
I also run 16amp with lite weight flywheel on 2.5 but I run carbs also so was just wondering bout efi. To the op. If u really wanna run lite weight wheel just swap to 16 system if u have it b easiest
12-22-2018, 10:11 PM #19Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
there were red and black 40 amp flex plate flywheels ive had plenty of both colors no difference in them weight wise, they weigh 11.5 pounds and the cast wheel weight almost 13 pounds so like said above they are not that much lighter but im running one on my pmax , James cut this one up pretty good its has more then the stock pm in every range me being a motor builder for a while now( and almost ready to quit) i had lots of motors on my Bullet, 29 i think in the 24 years ive had it since new from a 300x down all the way to a 200 efi and every size in between it was fun at the time but im getting old 73 now only did 6 motors this year bout a third of what i did a few years ago
01-13-2019, 12:16 PM #205000 RPM
- Sep 2014
- piedmont S.C./hickory hill TN.
- 187
- 11
I have a black/dark grey 200HP 16amp flywheel.It weighs 9lbs. 14oz.I am wanting to swap this onto my P/M.I also have the matching stator.what needs to be done?
01-13-2019, 01:21 PM #21TRANSPORT SERVICE...UP TO 33 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY
LIVE LIFE ON THE EDGE,LESS CROWED BETTER VIEW
01-13-2019, 02:17 PM #22
Need swap complete system,stator trigger,confirm ur boxes r gud for 16, and rectifier, some people keep 1 of the regulator instead of rectifier I believe, I use complete 2.4 16 amp system with 260 liter flywheel and works great, easiest way to go unless need charge for lots electronics
01-13-2019, 02:45 PM #23
LOL yes you have! Unfortunately one flywheel did not play well, lost a magnet since it was cleaned too well with lacquer thinner....
I personally have no problem running those red 40amp flywheels even though the weight savings is not huge every little bit helps that upper bearing and crank.
I have found duplicating the 245/260 16amp setup as was design has worked very well for me.
Frank Molé liked this post
01-13-2019, 03:39 PM #24TRANSPORT SERVICE...UP TO 33 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
01-14-2019, 05:01 AM #25
I found on my promax wit the 16amp, on short runs and not running a lot it was fine.
But with the vst and laser ecu etc it draws too much for the charging on long all day runs. This was with a group 24 cranking battery, maybe with a bigger bat like a group 27 or even a29/31 you’d have better luck
I got tired of jacking with it and have permanently put the 40 amp stuff back on full time.
To much hassle to swap swap it out to run and fish all day, vs having it on for play days.
Turning a 40amp over 8k a lot will fry regulators and stators too also FYI, don’t know how high you are turning. Yours.
01-23-2019, 11:45 AM #26
I bought a red to swap out my stock black and it would not clear the stator. Do you have to buy the older stator also?
01-23-2019, 11:50 AM #27
its probably for a 16 amp..... got a picture of it?
01-23-2019, 11:53 AM #28
There is a red 16 amp and a red 40 amp. If you have the red 16 amp it will not fit the 40 amp system...
Josh Peterson
01-23-2019, 11:53 AM #29
01-23-2019, 05:35 PM #30
I believe it got tossed in scrap bin. Bought it of the page.
OMC 225 HP flywheel
By cmn in forum Technical DiscussionReplies: 7Last Post: 05-11-2008, 10:25 AM
