Results 1 to 13 of 13
Thread: Transom brace
12-21-2018, 08:04 AM #1
Transom brace
What is the best way to brace a good transom? I've ran all thread thru transom and connect to the deck but want a cleaner look. It's a rigged boat minus motor at moment , boat is rated for 175 and will b putting a very healthy 200 on it, add knees maybe? If theres room? Ideas plz. Bass boat
12-21-2018, 08:09 AM #2Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Easiest is to put an alum. plate on the exterior with a plate on the interior at the bolts to spread the load. Exterior plate should have a 90 deg. "ell'' shape at the top for strength. Lot of bass boats come with these type ofplates from the factory. Very effective. Knees are best, but can be very difficult to install correctly on some boats.
Will hedrick liked this post
12-21-2018, 08:13 AM #3
That sounds like a plan. Plate with bend at top to lip over top transom?
12-21-2018, 08:44 AM #4
I have made several with 4 pieces of aluminum. Plate for the back of boat, inside of motor well, under motor well, and top of transom. Place plate on back of boat and drill holes. Plate on inside of motor well and drill holes. Bolt it together then set plate on top of transom and tack in place. Remove from boat and weld permanent. Slide over transom and bolt motor in place. Take 4th piece and place it under motor well and use as a washer for bottom bolts thru motor. Never did this on a good transom, only as a band aid but it works well.
RockTeam Junk
12-21-2018, 08:45 AM #5Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Correct.... The 90 deg bend makes the plate much stronger. Also gives a finished look to the piece. 1/4''alum would be very strong. Might be able to go thinner. Ask your fabricator what ga. and alloy he recommends. I would prime and paint it before install. Inside and out.
Merc 2.5 thanked for this post
12-21-2018, 08:50 AM #6
I actually have a piece that came off a boat already that has the bend and holes drilled etc. Will prep and paint. Thanks guys
12-24-2018, 10:52 AM #75000 RPM
- Mar 2016
- cincinnati, ohio
- 662
- 142
- 32
- 278
- 191
Fast and easy would be to run the all thread thru some aluminum tubing or stainless to clean the look up????
12-24-2018, 11:08 AM #8
I have used the plastic split wire loom stuff to cover the all thread. Works well and keeps the threads from cutting your hands!
Josh Peterson
12-24-2018, 11:38 AM #9
12-24-2018, 12:50 PM #10
Merc 2.5 liked this post
12-24-2018, 03:44 PM #11
I used these stainless turnbuckles on my Switzer when I put in the new transom.Iwanted to tie it into the top deck as well.I glassed some reinforcement to th inside of the splash well,then made brackets for the top of the Jack plate.In the end it don't look to bad,is exceptionally strong,and adjustable.Here are a few pics.
12-24-2018, 09:26 PM #12
I do like the turn buckle idea. Alot easier to tighten after awhile.. if I was to wanna go all thread , I believe I'd give those a shot, for now cause it is in good shape, just gonna do big plate with channel that laps over top transom and big piece alum diamond plate on inside for bottom bolts
12-26-2018, 08:05 AM #13Screaming And Flying!
- 14,701
- 380
- 1280
- 5599
- 10934
Don't go overboard on the metal reinforcements. They add a lot of weight quickly. Use just enough, and lightening holes are good.
NICE PAIR liked this post
STV Transom Brace
By aggiestckl in forum General Boating DiscussionReplies: 10Last Post: 04-15-2016, 01:40 PM -
internal transom brace pics please ( cougar mtr 19')
By beamrverbeek in forum Props, Setup, and RiggingReplies: 0Last Post: 07-08-2008, 07:21 PM -
Transom brace (this is for you, Superdave)
By tombrown in forum Technical DiscussionReplies: 18Last Post: 11-29-2001, 09:55 AM
