Results 16 to 26 of 26
Thread: 300xs DBR 1.1 or 1.3 software
01-14-2019, 07:38 AM #165000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
darkdream thanked for this post
01-14-2019, 08:15 AM #175000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
01-16-2019, 04:15 AM #18
01-16-2019, 12:32 PM #19
My 2005 250xs's have the fuel rail water hoses hooked up when I bought them
Aaron
Fountain 38TE, quad 400 Verados
Talon F20 Flats boat, 250XS
01-16-2019, 08:57 PM #20
01-16-2019, 09:22 PM #215000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
01-17-2019, 12:18 AM #22
Thanks I hope somebody can confirm heard the same but not sure. Tried to get in contact to dbr by mail but think to busy. Don't know what happen if run temp sensor out when have to be in? Temp out is more rich? Dont want to kill my engine due a simple mistake...
Boat: Hydrostream virage
Engine: Mercury 300 XS DBR 1.3
Props: 32' performance drag4 ,buckshot gen2 4 blade cleaver 34'
Max speed: 113mph
01-17-2019, 11:57 AM #235000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
You will be fine running sensor out.
Fyi that is not a true air intake temp sensor it's a coolant/water temp sensor. It's just there to give a reading too calibrate fuel mixture.
So in theory now that you removed temp sensor it should be more cooler because it doesn't have heat transfer from intake plenum now which should make engine run little richer.
If you have doubts pull couple spark plug before and after to read fuel mixture
01-18-2019, 05:23 PM #24
It is an Opti. The computer will compensate for any rich (or lean) condition. The re-positioning of the temperature sensor is to keep the sensor in ambient air, not heat soaked by the intake manifold aluminum after a bit of time which gives the ECM inaccurate air temp data. That way the temp input data to the ECM will be the temp of the incoming air, not the temp of the aluminum of the manifold. This info according to DBR and common sense engine input/output sensor/ECU parameter knowledge.
Both the 1.1 and 1.3 recommend the sensor re-positioning for this reason. All the hype about the DBR tune (re-flash) is very subtle, if at all noticed without a dyno (adjusted to fit the message from DBR ), IMO. Just little tweeks like the sensor re-positioning, a higher rev limit, etc. are gained by the DBR tune. If you study the HP and torque curves of an Opti, you will notice max HP and torque well below the stock rev limit, so raising the rev limit accomplishes little to nothing. You engine should be propped to "OPTI"mize the max. HP and torque in that sweet spot or your missing the "boat". Mother Mercury is hard to beat in the R&D - HP extraction game!
01-23-2019, 10:32 PM #25
I was impressed by the performance difference. This is real-world testing on a bass boat with a data logger. This test wasn't for all out top end. I did see an improvement with my big wheel top end numbers as well. Honestly, I haven't pushed it yet. Like mentioned, I prop for under 6k for topend.
I also tested the MadEFI flywheel. Look how the flywheel plus DBR would have impacted holeshot. I fish, so I made some necessary changes and the full impact wasn't seen.
Allison XB21 2+2
01-24-2019, 03:56 AM #26
Thanks, I just placed the order great test movie hopefully it works also for me. Best thing is the new one is balanced for higher rpms and the stock flywheel not (what I heard)
Max speed: 113mph
Help. Looking for software
By vnemous in forum The Scream And Fly LoungeReplies: 6Last Post: 02-16-2012, 03:42 PM -
Pcu software Woe's?
By pirogue in forum Technical DiscussionReplies: 3Last Post: 11-01-2007, 10:34 PM -
dvd software
By P man in forum Computer and Forum SupportReplies: 4Last Post: 10-08-2004, 02:06 PM -
Another software Q
By Scott in forum The Scream And Fly LoungeReplies: 4Last Post: 03-13-2003, 10:39 PM -
Need help from you software gurus !!! Website design software .........
By Balzy in forum The Scream And Fly LoungeReplies: 6Last Post: 03-13-2003, 09:37 PM
