Results 1 to 15 of 26
    Netherlands
    300xs DBR 1.1 or 1.3 software
    Who knows the difference between DBR 1.1 and 1.3 software for 300xs ? Live in Europe so I was afraid to send my only pcm to DBR (if shipping go wrong I can buy new one) so now bought a spare pcm in Europe with already DBR software on it seller was not sure if it was the 1.1 or 1.3 (he was almost sure the 1.3) he send it over to dbr in the winter of 2016-2017. Are the mods the same? Just replace air temp sensor place intake donut and install faceplate or alien cowling? What size hole I have to drill if I keep the stock cowling?
    Can't wait to try it what gain it will give
    Boat: Hydrostream virage
    Engine: Mercury 300 XS DBR 1.3
    Props: 32' performance drag4 ,buckshot gen2 4 blade cleaver 34'
    Max speed: 113mph
    Aug 2012
    Tenkiller Lake, OK
    Dark, It probably is the 1.3 with that late flash date. Yes the same procedure for the air sensor and intake ring. I did back to back tests on a friends 30 Skater and it showed no performance gains. I run the 1.3's om my 28 Skater, but have not done a back to back test on the 28. Post your results, please.
  3. Thanks darkdream thanked for this post
    Netherlands
    Thanks for your reply let know the gains in this topic topspeed now 110 mph with humpback 15x34 pitch. Did you have instructions were to put the temp sensor and how big the hole in cowling must be if I change the stock cowling with faceplate?
    Max speed: 113mph
    Aug 2012
    Tenkiller Lake, OK
    The temp sensor is just zip-tied to the top of the intake plenum (to the wires on top). The threaded hole where the temp sensor was is filled with an allen screw with an o-ring. The hole in the front of the cowl is 5" per Joe at DBR. I have not done the cowl hole, however, just replaced the cowl with Nass alien cowls.
  6. Thanks darkdream thanked for this post
    Netherlands
    Thanks again! Great info so air temp replacement is easy. Is there a big difference in performance between running modified stock cowl with front plate and Nass style alien cowling? And how much gain you get between bone stock and DBR flash? Hopefully it give me a few mph. Hard to find bigger props already run 15x34' 4 blades so will love the 6800 limiter.
    Max speed: 113mph
    Aug 2010
    Barrie, Ontario, Canada
    Quote Originally Posted by darkdream View Post
    DBR suggest you install the intake ring with 5200 sealant so it stays on. The set screws do not hold!!
    Triad V21 #002 - 15in DBR 300 xs
    19' J-Craft - 175 Opti
    18' Pontoon - 115 CT 4S
  9. Thanks darkdream thanked for this post
    Netherlands
    Thanks, don't have the intake ring bought only the pcm. Think to buy the billet mad efi intake donut think it will be the same ring. Now have to think about whats better the expensive but really nice alien cowling, or modify the stock cowl
    Max speed: 113mph
    Aug 2012
    Tenkiller Lake, OK
    Don't get your hopes up too high! The biggest advantage to the "Nass" style alien cowl is the weight savings. Invest in a Dewald prop for the biggest bang for the buck! JMO
  12. Likes V-bottom, Kcraft liked this post
  13. #9
    FLA
    Davidlake is dead on get yourself a 35 Dewald you want need 6800 . About 4-5 MPH faster than the humback in back to back test runs and better handling on my Twister .
    24 Twister
    Aug 2010
    I just picked up a 34 dewald that I can hardly wait to try. Unfortunately our water here is another 4 months before it it becomes liquid again
  15. Likes Kcraft liked this post
  16. #11
    Netherlands
    I just reciept a mad efi velocity stack and orderd a faceplate from Mike Nass. Now only looking for the right mods to do. Spoke to somebody who said replace air temp sensor only needed for first flashes 1.1 and no needed for 1.3 and heard about a mod to cool the fuel rail? Hopefully somebody can help me with clear instructions
    Thanks
    Max speed: 113mph
    Aug 2012
    Tenkiller Lake, OK
    Temp sensor re-positioning is required for the 1.3. Don't know about the fuel rail cooling.
  18. Thanks darkdream thanked for this post
  19. #13
    Netherlands
    Thanks so for 100% both 1.1 and 1.3 require same mods just air temp senor replacement? And cowl mod. This is the fuel rail mod someone told me. Souds like a good idea. Click image for larger version.
    Max speed: 113mph
  20. #14
    May 2007
    STL
    When I adde dbr kit, my 250 already had fuel rail mod. Seems some motors cane from factory that way and some didn’t.
    Moving temp sensor is super easy. Cutting and modding cowl is most time consuming
    [IMG][/IMG]
  21. Thanks darkdream thanked for this post
  22. #15
    Netherlands
    Thanks for the reply so all the dbr flashes require this air temp replacement? Just afraid for damage if its not real needed for newer flashes. And thanks will do the same my fuel rail don't know Mercury did this only for the early xs engines but its easy to do
    Max speed: 113mph
  1. Help. Looking for software
    By vnemous in forum The Scream And Fly Lounge
    Last Post: 02-16-2012, 03:42 PM
  2. Pcu software Woe's?
    By pirogue in forum Technical Discussion
    Last Post: 11-01-2007, 10:34 PM
  3. dvd software
    By P man in forum Computer and Forum Support
    Last Post: 10-08-2004, 02:06 PM
  4. Another software Q
    By Scott in forum The Scream And Fly Lounge
    Last Post: 03-13-2003, 10:39 PM
  5. Replies: 6
    Last Post: 03-13-2003, 09:37 PM
