Results 1 to 4 of 4
Thread: Baystar vs Seastar
12-19-2018, 07:03 PM #1
Baystar vs Seastar
Whats the difference in the helms, other than fluid capacity? I have a Seastar system, but my helm is bad and leaks. Can a Baystar helm be used with a Seastar steering cylinder?
12-26-2018, 11:15 AM #2
Main differences are the internals of the 2 system, seastar is made with higher grade components, stainless etc, the helms and cylinders can be used together, they are interchangeable.
15.5 cobra 175 hp merc - sold
18 tahiti tiger O/B 200 hp merc - sold
19 STV euro - 2.5 merc DRAG
Seebold F1 tunnel - 2.0 F1/champ
58Evinrude thanked for this post
12-26-2018, 01:08 PM #3
Baystar is a lower hp rated system as I recall. I would check the relief valve pressure and the capacity of the helm.
18 Talon/2.4 carb SOLD
26 Deck Boat/250 Merc
01-24-2019, 07:33 AM #4Member
- Mar 2018
- Wheeling, WV
- 39
- 10
I’m pretty sure the BayStar systems are 1000psi relief valves.
1.1, 1.4 and 1.6 ci/rev displacement. You’ll have to look up your cyclider P/N and get the volume, divide the volume by output to get the lock-to-lock.
ex. 8.34/1.4= 5.9 turns lock-to-lock.
The SeaStar is supposed to be a more efficient pump that that’s lower effort and
are also 1000psi relief valve, available in 1.7 and 2.0 ci/rev.
The 2.0 would give you about 4.2 turns (assuming an 8.34 ci cylinder volume).
Both systems have the NFB valves in them.Last edited by 304Mirage; 01-24-2019 at 09:34 AM.
58Evinrude thanked for this post58Evinrude liked this post
Where do you find an extra Baystar/Seastar tube nut and olive?
By pcrussell50 in forum General Boating DiscussionReplies: 0Last Post: 08-07-2016, 03:26 PM -
Baystar vs. Seastar
By Dawoo73180 in forum Technical DiscussionReplies: 10Last Post: 06-21-2008, 09:11 PM
