Results 16 to 24 of 24
12-24-2018, 11:51 AM #16Member
- Aug 2004
- Hillsboro MO
- 59
Poky,
I noted smoke as one of the complaints with the 175 is high smoke at idle, thus plugs tend to foul if idling through no wakes.
Things to consider:
The 175 SJ dynos at the impeller shaft closer to 200 than 175.
I've never dropped a stock ProMax PH on a SJ pump. To do so will require a SJ crank or custom machined pump input shaft. The 175 SJ "water box" and exhaust manifold are the limiting factors to increased power. However, removing the foam pump seals to intake tunnel would help flow a bit more freely (read loud). Maybe someone with knowledge of the ProMax mapping could provide some insight.
I'd have to go back and reread the thread, however I think provided my opinion to the majority of your questions. No matter what route you take, I wish you luck with the project. KT
12-24-2018, 05:59 PM #17Junior Member
- Jun 2008
- North Port Fl
- 10
What's the hull speed of the sea raider? Just a thought.
12-24-2018, 11:10 PM #185000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
my last sea rayder with a 175 ran 5500 rpm and 52 mph, and a amazing hole shot.
a question on power from Kevin, if the `175 SP is more like a 200, then how is it a 240 is more like a 225 pro max? for the smoke, I guess I grew up with outboards, if they start to smoke, nail the throttle and clean her out.
12-25-2018, 11:02 AM #195000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
I don't think I would remove the baffles, on my last SJ I melted the control cables that run right past the baffles. I would think that with out them, you would melt them even faster, In the spring, I'm going to look into moving them outside of the pump, or as my wife said, try to wrap them.
12-25-2018, 01:05 PM #20Member
- Aug 2004
- Hillsboro MO
- 59
Poky-
I don't think we are on the same page here. I was replying to your above statement that a 175 was more like a 150. In actuality, most 175 SJs that came off the line produced +/- 190HP at the impeller shaft. As to smoke, I was sharing my experience of idling through long no wake zones. With a direct drive impeller, nailing the throttle to clean her out could get one in trouble.
Disregard the factory SJ/PM ratings as the early FI 2.5 SJ & FI 2.5 ProMax can produce near the same power.
As I find time, I share with you why your cables melted.
12-25-2018, 03:27 PM #215000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
for hp, I was told that a 175 SJ was comparable to a 150 OB and that a 240 was comparable to a 225 pro max outboard. and I melted my cables on a rare day on Green Bay that was flat, and we ran a WOT for some time
12-30-2018, 06:48 PM #225000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
find it interesting that the outboards are so closely rated for hp and the jets are much more lose. or at least sated much differently. look at a outboard rating vs a outboard jet.
12-30-2018, 07:16 PM #23Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
SeaDoo had a jet boat a few years back with a 3.0 250 Opti. Not sure how they rated that one.
12-30-2018, 07:52 PM #245000 RPM
- Aug 2014
- West Bend, WI
- 289
- 55
1996 Sea Rayder Battery Question.
By zooterboy in forum Technical DiscussionReplies: 0Last Post: 12-13-2009, 10:22 PM -
need advice on 1996 sea rayder f-16
By allisonmo2 in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 04-16-2009, 04:35 PM -
Sea rayder 1994
By Wilf in forum Jet Boats, V-Drives and Stern DrivesReplies: 2Last Post: 06-14-2008, 07:13 AM -
Need advice on Sea Rayder 120HP jet boat
By PilotSmith in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 01-20-2008, 02:41 AM -
Sea Rayder-looking to buy, need advice
By jetlvr in forum Jet Boats, V-Drives and Stern DrivesReplies: 5Last Post: 07-18-2002, 06:44 PM
