Results 1 to 6 of 6
    Aug 2012
    beaumont, tx
    carb setups...pics
    let see some carb setups...plumbing, fuel logs, regs...etc etc etc
    fuel line size?
    dead head setups and bypass
  2. Likes Baker343 liked this post
    Jul 2012
    Lufkin, Texas
    I don't have any pics, but I recommend a bypass setup! I had a dead head setup and the floats on the bottom carbs bend over time. It's a pain in the neck to pull them off and fix a couple times a year! I talked to others at the party who have had the same problem so it's not just me...
    I would run a bypass regulator in the cowling with a cross over line from the pressure to the return with a small orifice in it like some of the efi setups to bleed off excess pressure after shutdown. I would put the inlets on one side and pull the plugs on the other side and tee those together for the return.
    It's a lot of plumbing but it will keep everything happy and also eliminate heat soak problems on restart because cool fuel will constantly be circulating through rhe carbs when the pump is on!
    Thant's my 2 cents...
    Josh Peterson
    Aug 2012
    beaumont, tx
    slow down....im a efi guy......need pic i can color with crayons until i understand it
  5. Likes nitro_rat, Baker343 liked this post
    Jul 2012
    Lufkin, Texas
    Sorry, I'm stuck in a hotel room, no pics!
    The float bowls are drilled and tapped for a fuel inlet on both sides. Factory fuel system uses one side or the other. There is a plug in the unused side. I'm saying pull the plug and install a second set of inlets. Now you can have fuel going in one side and out the other.
    Put your return regulator in the cowl, could probably make a bracket to mount it where the pulse pump was.
    The trick is to run a hose to tie the pressure and return sides together. Stuff a jet or other small orifice in this line so that it will bleed off pressure after shutdown. This will keep stored pressure from bending your floats!
    I'll try to dig up some crayons...
    Josh Peterson
  7. Likes texasvector liked this post
    Aug 2012
    beaumont, tx
    makes sense now
    still could use some crayons
  9. Likes nitro_rat liked this post
  10. #6
    Dec 2001
    I like crayons..... Yummmmy.
  11. Likes texasvector, rock, NICE PAIR liked this post
  1. Best steering setups??????
    By 88starflite21 in forum Props, Setup, and Rigging
    Last Post: 04-18-2013, 03:54 PM
  2. Looking for pics of hatch/seat setups
    By dorton in forum General Boating Discussion
    Last Post: 12-08-2010, 06:51 PM
  3. switzer setups?
    By 83switzer in forum Props, Setup, and Rigging
    Last Post: 04-01-2003, 11:09 PM
  4. Checkmate Mx-13 setups?
    By 10.5' Tunnel in forum Props, Setup, and Rigging
    Last Post: 03-30-2003, 10:20 PM
  5. setups tried and proven
    By blkmtrfan in forum Posting Questions and Suggestions
    Last Post: 03-10-2003, 11:47 AM
