Results 1 to 10 of 10
Thread: Bleeder lines
    Nov 2016
    Missouri
    Bleeder lines
    What is everyone using for replacing bleeder lines ?....I noticed mine are getting kind of gummy feeling...Thanks..
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
    Plainville, CT
    Years back when I updated my XR4 with composite reeds I replaced all the bleed lines with just regular fuel hose from Napa. It actually appeared more durable than the original stuff. The only thing I noticed it that it wasn't exactly the right size, but slightly larger. So the ties that I secured it with were pretty necessary.
    A lot of guys seem to like tygon, but I worry a lot about the effect of heat on that stuff and its durability.
    I'll be doing another engine soon and am seriosuly thinking about going with OEM.
    Sep 2017
    Ashland city tn
    I got mine pro marine , tygon, very gud stuff I think , can see what's goin on and stays soft. Hasnt been on that long yet but no change of stiffness or nething. I used small yellow zip ties also
    Nov 2001
    upstate newyork
    I'm pretty sure you can go to a hobby shop and get the stuff they use for fuel lines on boats and cars.
    Pekin, IL
    Tried the tygon for a while but it is just too loose fitting to suit me. Tie wraps will make it work but good old black tight fit has gotta be the way to go. Buy mine from Pro Marine.
    Rock
    Team Junk
    Sep 2017
    Ashland city tn
    Not sure if it makes a difference but I got mine was 3/32 I think. Actually for PwC oiling lines. They fit snug over bleed fitting but is a soft plastic
    Pekin, IL
    Tygon sure makes em look good.
    Rock
    Team Junk
    Apr 2016
    Victoria bc canada
    I've used fast fuel line, works great, good pricing, tight fit, multiple colors.
    https://fuel-line.com
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
  9. Likes FORBESAUTO liked this post
  10. #9
    Plainville, CT
    Quote Originally Posted by Brookbbb View Post
    The heat tolerance listed for that is 223F, whereas the Tygon I see is listed at 165F. So that is a good thing.
  11. #10
    Feb 2014
    Missouri
    Typically factory, plus can see the oil to check check valve operation.
    Curious why yours are gummy? Some additive or butyl ether gas? How are the recirculating lines?
  1. Mercury Tech: 2.4L bleeder line & water lines T-REX
    By YELLOWSS in forum Technical Discussion
    Last Post: 04-06-2011, 02:39 PM
  2. OMC Tech: 3cyl 35 bleeder lines
    By CALVIN in forum Technical Discussion
    Last Post: 08-01-2009, 12:25 PM
  3. Bleeder Lines
    By Dan Young in forum Technical Discussion
    Last Post: 10-24-2003, 07:54 AM
  4. Bleeder Lines
    By Liqui-Fly in forum Technical Discussion
    Last Post: 06-13-2001, 08:45 AM
