Results 31 to 45 of 59
Thread: Hydra bass
  1. #31
    Sep 2017
    Ashland city tn
    Kinda cold today but took her for a very short run , boat should be gud for 80s neway , gonna take seat time to figure out where jackplate like to be and gonna do prop change for for next trip. Seems like needs more bow lift, could had been me with jackplate not n route spot but I'll figure out details,, over all boat rides really well at speed ,Click image for larger version.
  2. #32
    Sep 2017
    Ashland city tn
    Here she is with a little bit cleaning
  3. Likes timmc6, Bruce2, Baker343 liked this post
  4. #33
    Sep 2017
    Ashland city tn
    Well I got little decent weather to give boat a gud run after installing all fishin stuff. I found a decent spot for jackplate and run her up to 72 like it was on rails , now I didnt have it wot ,cause I'm not completely sure shes broke in completely. There was no chine walk up to 72. Maybe it will when it touches 80 idk yet but it will run 80+ for sure. Had lots lots of rain lately and river is trashy so I dont wanna push my luck today , think I'll come back when it clears up sum and c if I cant get a pic of the GPS while runnin. All in all great boat so far
  5. Likes Ranger 1, Baker343 liked this post
  6. #34
    Sep 2017
    Ashland city tn
    I have been doin little reading on here and seems to have kinda copied the pad of a stream Ventura ,or viper or sumthin of that nature. What yall think? Definitely doesn't look like normal bass boat padClick image for larger version.
  7. #35
    Sep 2017
    Ashland city tn
    Hey guys got a ?,
    When I'm runnin and start rasing jackplate steering gets harder and harder to steer ,I do have torque tab runnin a 28 chopper, think a diff prop help with steer torque ? I wanna run motor hi as possible. Any suggestions??
    Without goin hydrolic not n the funds at moment
  8. #36
    Nov 2016
    Missouri
    I'm having that same issue on my 190 champion with 8 inch manual plate..the higher I raise motor the stiffer the steering gets but the faster the boat runs also..I'm running a stock out of the box 25 tempest... curious of answers you get merc2.5..
    Daddy taught me to never force anything but to just get a bigger hammer.
    1995 19'0" Champion bass boat
    1995 200 XRI
  9. #37
    Sep 2017
    Ashland city tn
    I have read other old post bout people swapping props and helps, guess it depends on hull,but I cant go buy 4 or 5 diff props to try, I've tried 2 28 choppers, one cut kinda like a e.t but they acted same or close
  10. #38
    May 2013
    Huntiington Beach Ca
    If you could get your hands on a 26 trophy or borrow. I think it would work really well with your set up. You can run them higher, they provide good all around lift, they can be improved for your setup by a good prop man. "Allison Cut" And if I remember right they don't wear your arms out as fast
  11. Likes Merc 2.5 liked this post
  12. #39
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Baker343 View Post
    Man that would b great but I would had never thought that a trophy would help with lwp and surfacing that much, I'm up to try it tho , the 28 I'm runnin now has added cup,and I can turn it to 7k or better, I'm thinkin ,havin trouble with tach and goin by hr/tach meter , still haven't maxed this motor out yet,
    Not electrical need new tach
  13. #40
    Jul 2012
    Lufkin, Texas
    May 2013
    I was testing a 25p Trophy worked on by Tim at Performance Propeller. He put a Allison cut on it. I was going to run this on my Baker running a 2L and a CLE in the Parker Enduro a couple races ago. It worked really good at carry 40 gallons of fuel. Very stable and it help my boat handle the rough water conditions. I really needed a 24p. Steering torque was considerably less with this 4 blade.
  15. Likes Merc 2.5 liked this post
  16. #42
    Sep 2017
    Ashland city tn
    Well guys. Figured I'd throw this out there but on previous post was havin steering torque bad, guess I just had jackplate way to hi , i started at bottom on jackplate (hyd) and came little at a time , got to point where had NO torque and ran up to 82 ,83 and back off. Tach was pegged at 6k long b4 I hit 80 ,little chine walk but.nothin to really talk bout , was easy to balance, damn if I dont think it hit 90 with current prop &set up , I did hit a damn stick bout 4 or 5ft long and 2 in round, river up little trashy but.not horrible, thought I was safe lolClick image for larger version.
    Was runnin bout 70 and couldn't get round it , who yall think I should send it to?
  17. #43
    Jul 2012
    Lufkin, Texas
    Is that your 28 chopper? Just send it to me, I need one...
    Josh Peterson
  18. #44
    Sep 2017
    Ashland city tn
    Did u see the dent?? I need it worked neway , little more now lift cause I actually need bout 2 more in of set back , ran damn gud today tho, but its spinning it well into 7k
  19. Likes nitro_rat liked this post
  20. #45
    Sep 2017
    Ashland city tn
    1st time I tried go out today damn motor wouldnt wouldnt start , thought it was solenoid but was starter ,and had swap starter and back to a green flywheel , o btw. I could tell a pretty significant difference from the lite weight
  1. Hydra Sports Bass Boat has gotta go.
    By JDI, Inc. in forum Hulls up to 20'
    Last Post: 05-05-2014, 06:07 PM
  2. Must see Hydra Sports bass boat
    Last Post: 12-08-2013, 03:40 PM
  3. 79 17' hydra sports bass
    By kracker in forum General Boating Discussion
    Last Post: 11-14-2012, 07:20 AM
  4. 77 Hydra-Sports Hydra-Flight 170 rebuild/mod
    By 77sportz in forum Fiberglass and Composites Discussion
    Last Post: 06-20-2012, 07:03 PM
  5. Hydra Sport 17 set up
    By Jeff_G in forum Technical Discussion
    Last Post: 03-24-2009, 02:09 PM
