Results 1 to 5 of 5
    Feb 2007
    Western Washington State
    A Little Confused - Advance module?
    I have a 1987 XR2 - I've had it for some years now - and my mechanic says that it doesn't have an advance module on it. I've read and understand that the idle stabilizer is crap, but what about the advance module? If the module is gone where should the static timing be set? I've been having some problems with it surging badly at high cruise speed, and sometimes from that speed if I bury the throttle it will die, at like 5000 rpm. We're trying to troubleshoot the problem. Thx.
    TX......somewhere?
    idle speed control/stabilizer only on your xr2.. sometimes described as "rev limiter".. yours had stabilizer, never had a "limiter".. it would have been mounted on top of tha air annunciator.. they can be a pia so most float test 'em pretty quick...…….
    problem sounds like fuel delivery of some sort.. age/condition lines from tank all tha way to carbs condition?.. maybe carbs and/or fuel pump need a little attention.. cleaned with all new gaskets inside and out.. I would do max of 20* crankin (no stabilizer) for now..
    idle/timin', rpm is set in tha water, in gear.. whatever makes ya "both" happy.. numbers don't mater..
    Feb 2007
    What I'm hearing and reading is that this outboard had an advance module on it from the factory, not an idle speed stabilizer. I'm also reading that people with these older motor removed the advance module. I can understand removing the idle stabilizer, but why the advance module?
    Sep 2017
    Ashland city tn
    Quote Originally Posted by croSSed View Post
    Yes remove it to.. if it was to go hay wire it would send ur timing thru the roof and burn up piston
    TX......somewhere?
    think ya mite be rite.. '87 had both 2 and 4.. xr4 I know had tha advance module.. so tha 2 probably did also.. jus getting old!.. really don't mater.. like said "float test" it.
  1. Removing advance module and det. Module sensor
    By Calvin1013 in forum Technical Discussion
    Last Post: 09-25-2018, 05:00 PM
  2. REmoved advance module and idle control module... Dangerous
    By Mark V in forum Technical Discussion
    Last Post: 06-05-2016, 03:13 AM
  3. advance module xr2 help
    By 1quickET in forum Technical Discussion
    Last Post: 06-11-2011, 11:09 PM
  4. advance module?
    By es1468 in forum Technical Discussion
    Last Post: 11-06-2007, 09:39 AM
  5. Getting rid of the timing advance module(s)?
    By CNT in forum Technical Discussion
    Last Post: 03-19-2005, 11:14 AM
