Results 1 to 4 of 4
    Dec 2018
    Washington
    OMC 3.6L V8 shifting problem
    1987 3.6L OMC sea drive v8. When shifting into neutral from either forward or reverse it feels like the something is binding up. We disconnected the shifter cable from the linkage at motor and everything moves fine, so it seems that the problem is somewhere between the gearcase and the connection to the cable. A local mechanic mentioned that the oring where the shift rod goes into the bottom end can deteriorate and create a problem. We may drop the bottom end this weekend and take a look at that. Are there any other ideas or typical problems we should look at?
    Hank
    Nov 2009
    hardyville va
    Quote Originally Posted by Hanksv View Post
    Hank
    O rings on the shift shaft for sure
    Feb 2003
    Could be lower mounts and upper have shift rod pushed into steering arm tube, shift assist switch, orings in shift cover top of lower unit or have cobra drive gears with steeper ram on gear and clutch dog, sticking detent ball. what rpm does it idle at should be about 1000 rpm.
    Just Some of the things I have seen Keith
  4. Likes powerabout liked this post
    Dec 2018
    Washington
    Hey guys. Sorry I didn't report back. Better late than never, I guess. It turned out to be the lower mounts had corroded and swelled enough so that the shift rod was rubbing inside the midsection. Had to do a bunch of drilling and grinding to get them out. Shifts like butter now.
  6. Likes powerabout liked this post
  1. CLE shifting problem?
    By beck427 in forum Technical Discussion
    Last Post: 07-15-2009, 06:24 PM
  2. Problem with shifting into reverse
    By tkite in forum Props, Setup, and Rigging
    Last Post: 03-31-2009, 11:09 PM
  3. Help with my shifting problem
    By 85allison in forum Technical Discussion
    Last Post: 06-01-2007, 08:52 AM
  4. 150 v6 shifting problem
    By ESOXGUY in forum General Boating Discussion
    Last Post: 07-12-2003, 05:19 PM
