Results 1 to 15 of 19
Thread: 250xs single ram to 3 ram swap?
12-12-2018, 03:11 PM #1Junior Member
- Oct 2007
- 16
How difficult is this swap? Ive heard of it being done before. I have a 302 Scarab Im trying to repower with a set of Optimax engines, but Ive only found a couple sets of XS engines. Im not rigged for it currently and dont want to add more pumps and holes to my transom. Do I need to swap the whole midsection or can just the transom mount and trim system be swaped?
12-12-2018, 03:26 PM #25000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
I thought they were 3 ram?
12-12-2018, 04:24 PM #3
Good news is you can swap clamp only. Bad news is that you have to pull powerhead to get to the nuts on top mount. May be less work to mount pumps.
12-12-2018, 05:53 PM #4Junior Member
- Oct 2007
- 16
Thanks for the reply, may have to keep searching for a couple non XS motors.
12-13-2018, 05:25 AM #5
12-13-2018, 05:37 AM #6Junior Member
- Oct 2007
- 16
12-13-2018, 05:43 AM #7
they come factory with tha three ram production trim.. should not have single ram, pump in tha boat..…..
have you seen tha motors?
12-13-2018, 08:05 AM #8Junior Member
- Oct 2007
- 16
Have not seen them in person, one set is 2005 and the other is 2007 Both 250xs. Both owners have indicated that they have pumps in the boat.
12-13-2018, 08:18 AM #9
they shouldn't be.. go here to see parts list for all XS and other high performance motors...
http://www.marineengine.com/parts/me...utboard-parts/
12-13-2018, 08:56 AM #10Junior Member
- Oct 2007
- 16
You are 100% correct, the parts list on that site shows them with trim on the motors. But all of the owners ive talked to and pictures I could find on the web show external pumps for all XS engines. Not sure it would be worth the extra rigging on my boat. Are they any more or less reliable than a normal opti? High octane is not an issue, we have it at the marina.
12-13-2018, 09:02 AM #11
The 250XS is available with Transome Bracket (Heavy Duty) which is single ram with pump in boat. In answer to your question If you get a 3 ram clamp bracket you can switch it and loose the pump in the boat and save some weight. Though I have broken a couple of the lighter standard 3 ram clamp brackets and changed over to heavy duty clamp on both my 250 efi and my 300x.
12-13-2018, 09:30 AM #12
12-13-2018, 09:57 AM #13Junior Member
- Oct 2007
- 16
Thanks for all the info guys.
12-13-2018, 12:01 PM #14
12-13-2018, 12:11 PM #15
They come any way you want it. When I bought my 300x it had an offshore mid with a 3 ram clamp go figure.
Mercury Tech: 2005 250XS powerhead swap with a 2006 225 Optimax
By cr250 in forum Technical DiscussionReplies: 3Last Post: 10-10-2017, 09:27 PM -
250xs 250xb power head swap questions
By jeepster21 in forum Technical DiscussionReplies: 3Last Post: 08-23-2015, 09:52 PM -
PCM swap on 250xs
By Donat in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 5Last Post: 05-07-2012, 06:03 AM -
250XS block swap
By Da Bull in forum Technical DiscussionReplies: 5Last Post: 08-26-2011, 12:34 PM
