Results 1 to 2 of 2
    Aug 2004
    kingdom of bahrain
    jack plate hight????????
    dear members
    I have got action boat (wight without driver 490 kg) powred by 260 hp mercury efi prop: 24 yamaha chopper
    could please recommend me the correct hight jack plate set up from the bottom of the pad
    also what prop do you recommend for the above action boat
    you early answer will highly appreciated
    thank you very much
    its not always the gun its the man behind the trigger
    Mar 2009
    Port Saint Lucie
    prop shaft should be level with the bottom of the boat at its highest at least. As long as you have a low water pickup. I ran a 26 and 29 pitch on the 16 I had.
  1. Bolt on cav plate and/or bottom plate on jack plate for an STV Euro
    By Brookbbb in forum Props, Setup, and Rigging
    Last Post: 03-17-2017, 12:26 AM
  2. Rapid Jack Magnum 6" Jack Plate
    By SouthernComfort in forum Misc. Parts and Accessories
    Last Post: 02-16-2016, 11:03 PM
  3. Manual Jack Plate vs Hydraulic Jack Plate
    By Burchoid in forum Props, Setup, and Rigging
    Last Post: 05-25-2012, 05:00 AM
  4. Jack Plate Problem - Manual Rapid Jack
    By croSSed in forum Props, Setup, and Rigging
    Last Post: 06-30-2008, 11:43 AM
