Results 1 to 15 of 35
Thread: First time-Brucato acu
12-11-2018, 11:16 AM #15000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Going to lake test my boat this weekend after installing a acu removing oil injection and new boyeson reeds. Anything I need to look out for the first time I run it? Suppose to be turn key from Brucato correct? Ran it on the hose and the idle seemed a bit high like 1200. But it’s also not in a lake withbackpressure ect. It’s always idled kinda high though. Seemed to be real smoky on the hose. Mixed at 40:1. Maybe getting too much fuel at idle? Just don’t want to hurt this thing first time out.
12-11-2018, 11:22 AM #25000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Sorry it’s on my stock 225 promax on my 20.8 lavey
12-11-2018, 01:29 PM #3
They come pretty close if you are going to make changes get a note book to record where you started and what changes you have made. you need to be able to read plugs and piston wash if you are going to make changes in the upper rpm safely. Take your time and don't make more than one change at a time then drive it a bit.
KIRCHNER liked this post
12-11-2018, 01:47 PM #4
It's gonna smoke idling at 40:1 oil ratio (versus 100:1 with the oil injection); you're just going to have to live with that if you don't want oil injection.
12-11-2018, 02:42 PM #55000 RPM
- Aug 2006
- GA
- 855
- 25
- 35
- 71
... Run It..
12-11-2018, 03:13 PM #6
Frank Molé liked this post
12-11-2018, 04:07 PM #7
Brucato boxes come on the rich side, they leave it up to the owner to ruin everything.
12-11-2018, 07:00 PM #85000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
12-11-2018, 07:17 PM #9
Bunger thanked for this post
12-11-2018, 07:20 PM #105000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
ALso 40:1 or 50:1? Stock promax usually run av gas cause it’s the only way I can get ethanol free in commiefornia. Merc premium plus oil. Usually cruisin with a couple wide open passes.
12-11-2018, 07:50 PM #11
KIRCHNER thanked for this postW2F a V-King liked this post
12-11-2018, 07:52 PM #125000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
12-11-2018, 08:11 PM #13
Motor was designed for pump gas, running way more octane than it needs is just putting out the fire. The more the octane the less flammable the fuel.
12-11-2018, 08:13 PM #145000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
What cc heads would I want for straight at or even a 91/am 50-50mix?
12-11-2018, 08:21 PM #15
Stock heads are fine...your not racing but the idle quality will suffer a bit with av gas
One more time for Tony Brucato and Wife!
By skydog in forum The Scream And Fly LoungeReplies: 0Last Post: 05-24-2005, 07:00 PM -
Tony Brucato...Tankz, big time
By T-REX in forum General Boating DiscussionReplies: 6Last Post: 10-19-2002, 11:51 PM
