Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 121 to 135 of 146
  1. #121
    Australia
    Yes
  2. #122
    Dec 2011
    Ludington michigan,on the shore
    I'm a little confused but,the stringers are complete and finished.They were bedded into a Cabosile paste then tabbed to the floor with a 10oz 4" tape then covered in a 8 1/2 oz biax that also runs out onto the floor.The rear is notched into the transom 3/16 with one course of 1700 and two of 10oz the front is just tabbed to seat box with multiple layers of 8 1/2 oz If you're wondering iif they will run Forword of the seat box the answer is no,When I'm finished I will post a summery of cost,time,and why I did what I did.The center of this boat now has three layers of 1700 mat,one layer of 8 1/2 oz biax and one inch of balsa!
  3. #123
  4. Thanks outasite thanked for this post
  5. #124
  10. Likes W2F a V-King, NICE PAIR liked this post
  11. #129
    upstate N.Y.
    yes , he has a pilot's license !!!
    why ask me ?
  12. Likes NICE PAIR liked this post
  13. #130
    Aug 2015
    NE Tennessee
    And builds small airplanes ....
  14. #131
    Dec 2011
    Phase one is complete.Time to flip it and tidy up the bottom.Click image for larger version.
ID:	432391Click image for larger version.
ID:	432392Click image for larger version.
  15. Likes W2F a V-King, tnelsmn, rjdubiel, NICE PAIR liked this post
  16. #132
    Dec 2011
    A short summary to date.Time three months,around 225 hours.Material,twenty yards of 50 inch 1700 biax and 8 1/2 oz biax,7gallons of epoxy,2 sheets of plywood (with a lot leftover for the next project) seven 2x4' sheets of balsa,and a ton of brushes,cups,stir sticks sandpaper,grinding wheels, ect,ect $2700.00 A few things worth noting.Removing good balsa core SUCKS!--- I've learned to love epoxy---increase gelcote catalist from 2%to3% below 65 degrees.Under my seat and at the drain plug I left some clear glass that I can see the balsa through,a good way to detect water in the core.Extended the four outer stringers three to four inches.I ran two layers of 1700 plus an 8 1/2 oz cloth 50 inches wide full length forward until the corners were near the rub rail.This addresses the flexing at the hard point in front of the seat box and allows a (controlled flex) across all of the strakes.I considered extending the stringers,and adding more core.But in the end decided that there has to be some give somewhere,and core and strakes don't like to give.Also keep in mind that the top deck supports that attaches to the side stringers are very important in the overall strength,be sure they are tight,and kept that way.Anyway enough rambling,time to get to work on the bottom.Got some cool stuff to do down there. Here is a picture of the simple,but I believe effective front repair.Click image for larger version.
  17. Thanks NICE PAIR, V pads, LakeFever thanked for this post
  18. #133
    Dec 2011
    Well the bottom turned out to be more work than planned! I knew that as built the front bow area was thin,wasn't till I got to repairing some "white glass" up there I found out how thin! Also quite a bit of damage was done removing the core that was not rotten.so most of the gel neded to be ground away,then the intire bottom covered with a coating of epoxy rubbed on then wiped off.After that cured then another sanding back to polyester.Im now almost ready for some duratec primer on the repairs.Click image for larger version.
ID:	433896Click image for larger version.
ID:	433897Click image for larger version.
ID:	433898Click image for larger version.
ID:	433899Click image for larger version.
ID:	433900Click image for larger version.
  19. Likes tnelsmn, texasvector, LakeFever liked this post
  20. #134
    Jun 2018
    Floating around
    Hmm interesting trick rubbing the epoxy over it to seal it up I dig that idea! Mine is so thin you can see through the hull if you climb under the deck, freaked me out a little. Are you going to gel the bottom again or paint with base/clear urethane or?
  21. #135
    upstate N.Y.
    Is the sap running?
    why ask me ?
