Page 6 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 76 to 90 of 146
  1. #76
    Mar 2004
    Brooklyn Park, MN
    It looks like he is just pre-coating the balsa first with resin, then once that tacks up he will be putting down the glass. Balsa sucks up plenty of resin, so pre-coat the balsa always first, let that soak in, then add more resin and glass. With epoxy this is easy, with poly resin, you don't get that much time so you need to work fast with poly or vinyl resin.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  2. Thanks tnelsmn thanked for this post
    Likes texasvector liked this post
  3. #77
    Dec 2011
    Ludington michigan,on the shore
    Wow,that was a big piece to get down and straight! Click image for larger version.
ID:	428332Click image for larger version.
  4. Likes tnelsmn, W2F a V-King, nitro_rat liked this post
  5. #78
    Nov 2003
    Your work looks awesome! Thanks for sharing your progress.
  6. #79
    Aug 2015
    NE Tennessee
    Looking great ! That glass laid in one piece HAS to be strong
  7. #80
    Dec 2011
    Thanks,It was a long day.Took a while to get the drain fitting in place and pulled back to seal.Its hard to work that much 17oz mat at one time and keep it wet. but not to wet,get the air out,and and and.Now it's on to repairing the last cracked stringer. There will be be a splice right behind the seat box pics to follow.
  8. Likes nitro_rat, W2F a V-King liked this post
  9. #81
    Jul 2012
    Lufkin, Texas
    Keep up the good work Bob! Yours is one of my favorite 'Streams, nice to see it done right!
    Josh Peterson
  10. Likes W2F a V-King liked this post
  11. #82
    Dec 2011
    Removed the stringer section,and took the rest of the day off. Decided to cook off the epoxy,just to be sure it set properly.Will give it twenty four hours of good heat.Then back at it tomorrow.Click image for larger version.
ID:	428425Click image for larger version.
  12. Likes W2F a V-King liked this post
  13. #83
    Mar 2004
    Brooklyn Park, MN
    Another way other than heat for 24 hours is the way I do this, I think I finished my vking core about 5 years ago........ So she should be cured and good to have the floor put in soon!!!!
    Looks great Bob, I wish you did this 10 years ago so I could have used your techniques.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  14. #84
    Dec 2011
    Well the bright side, is the slower epoxy cures the stronger it is.So by now your Vking should be bullet proof!!!
  15. Likes rjdubiel, NICE PAIR, Capt.Insane-o liked this post
  16. #85
    Jun 2018
    Floating around
    Quote Originally Posted by outasite View Post
    Again I am so impressed with this resto I learned a ton thank you for sharing. Regarding this big single piece of glass how did you go abouts installing it? Did you start dry positioned and wet through it or?
  17. Likes NICE PAIR liked this post
  18. #86
    Dec 2011
    It was cut and fitted dry.Then removed and rolled onto a 1 1/2" pvc tube. The dry balsa was then given a heavy coat of epoxy at 9AM another at 10:30.At noon the fabric was laid on a plastic covered work bench and rolled,from the bottom up with a very heavy coat of epoxy,then rolled back onto the PVC tube.Then another coat of epoxy on the balsa.The 1700 was then rolled out in the boat from the rear to the front,working from the center out and foreword.There is no resin added from the top.As you roll,the resin will come to the top.Its much easier to bring the resin to the top than try to push it to the bottom.Not saying it's the best way but it has worked well for me.
  19. Thanks LakeFever, tnelsmn thanked for this post
    Likes LakeFever, W2F a V-King, NICE PAIR liked this post
  20. #87
    Jun 2018
    Floating around
    Genius, very helpful and well explained thank you!
  21. #88
    Dec 2011
    Today was spent fitting stringers.A simple jig was made to keep the stringers straight. The Hydrotec plywood is great to work with,Click image for larger version.
ID:	428642Click image for larger version.
ID:	428643Click image for larger version.
ID:	428644Click image for larger version.
ID:	428645 and meets British Standard 1088 (Good Stuff) And is much stronger than OE. nine ply vs five ply exterior building material.And not as heavy as I thought.The gap under the stringer will be held to less than 1/8". OE was 1/4" plus.They will be set in a bed of Cabosil,OE was not bedded.
  22. Thanks tnelsmn thanked for this post
  23. #89
    Oct 2017
    Hugo, MN
    Quote Originally Posted by W2F a V-King View Post
    Yes, my 79 production V-King (Not a Comp) had dry mat over rotted core. It also had open expansion holes on top of the unsealed foam filled float boxes, and I dug out a lot of wet foam. Needless to say the boxes got deleted.
    My 79 Viking had the core replaced by a previous owner, but the foam boxes in the wings are still there.
    Is there any way to know if mine are water-logged?
    2nd question, my boat lives EVERY day and night in an insulated garage. Only gets about 10-15 HOURS (1-1.5 hours at a time) a year on the water, then right back on the trailer and back inside. Could my foam boxes dry out if they ever got water in them?
  24. #90
    Aug 2015
    Southeast
    You can buy a moisture meter from Lowes for about $50. It will read through fiberglass. Very commonly used on big sportfishing wood core boats built in NC.
  25. Thanks Captaincj thanked for this post
    Likes outasite, NICE PAIR liked this post
