Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 61 to 75 of 146
  1. #61
    Coming along very nicely!....
    The true meaning of vacuum bagging......
  2. #62
    just read the whole thing very cool stuff..thanks.....
    TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
    DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
    LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
  3. #63
    Dec 2011
    Ludington michigan,on the shore
ID:	427786Well,a couple things new. The balsa top sheet cover under the dash is done. The second coarse of balsa in the pad got set today. A note worth mentioning,while looking things over yesterday I noticed some fairly big air pockets!I had rolled my work many times with the metal fin roller? So I've got a couple of options,ether grind them out and patch, or something I learned a long time ago.I went to farm and fleet and got a couple of large animal siringes,my plan, drill a pinhole and fill the void with resin. Ive done this in the past and 3-5CC will fill most,preferable to grinding out and patching.So I drilled carefully, and nothing but glass and CABOSIL! Then the lights came on.When removing the the core most of it was as good as new,so when it came up a lot of it brought the first layer of glass mat with it,leaving a "divit" So I made a paste of epoxy,CABOSIL and milled glass fibers and filled them.What I was seeing is the white paste under the glass not air.I did find a couple and filled them.Point is if you use a filler don't mistake it for air. Tomorrow,more balsa in the rear.
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg
  4. #64
    upstate N.Y.
    I'm beginning to think you just might know what you're doing ! My guess is it'll be a great platform for a 400 R !!!
    why ask me ?
  5. Likes NICE PAIR liked this post
  6. #65
    Dec 2011
    Nick, All I know how to do is old school.So the 400R is out. $$$$$
  7. #66
    Terrible job. EVERYBODY knows balsa is NO GOOD. In 75 or 80 years that hull will be nuthin but junk
    Jun 2018
    Floating around
    This thread is full on win! I like the idea of cutting the square sheets to make under the deck installation manageable. It is very tight under the dash I am sore just looking at your work, which is going at a great clip btw, im certainly impressed.
  9. Likes NICE PAIR, outasite liked this post
  10. #68
    Mar 2004
    Brooklyn Park, MN
    I bagged mine up there all in one section and then put one layer of glass all over that once the core was in. YOU AIN'T KIDDING ITS TIGHT! I ended up spilling my container of resin when I was starting to wet the glass over the core, I came out from under there looking like a porcupine with glass hanging off my arms!
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  11. Likes outasite liked this post
  12. #69
    Dec 2011
    Like the wife says "Bob just another one of your screw ups your kid will have to fix someday" LF the smaller pieces made it fairly easy to do the under dash area and the ridges of double 1700 don't hurt ether. The next piece I'm not looking forward to.One single piece of 50" of 1700 from the transom to the dash. And RJ you are not alone I got what's left of 20oz left behind my left outside stringer
  13. Likes rjdubiel, NICE PAIR liked this post
  14. #70
    Dec 2011
    Another little bit more today.Click image for larger version.
ID:	427945Click image for larger version.
  15. Likes W2F a V-King liked this post
  16. #71
    upstate N.Y.
    Quote Originally Posted by outasite View Post
    well in 10 years the 400r will be old school , probably being replaced with those silent electric motors that will make us pine for the old school 2 strokes !!!!!
    why ask me ?
  17. Likes outasite liked this post
  18. #72
    Dec 2011
    Yay! I got a core.Click image for larger version.
ID:	428003Click image for larger version.
  19. #73
    Aug 2012
    beaumont, tx
    looks terrific....gonna be solid as a rock!
  20. #74
    Dec 2011
    Well,today is the day. One last look before cover. It's out there guzzling up epoxy as I write.Going to give it a couple of hours,then have at it!Click image for larger version.
ID:	428318Click image for larger version.
  21. Likes rjdubiel, tnelsmn, W2F a V-King liked this post
  22. #75
    Minneapolis MN
    Are you putting straight resin over top of the core? Or is there a layer of glass down as well? Hard to tell in the pictures. I'm not far off of core going into mine. Thanks!
