Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 16 to 30 of 146
    Jun 2018
    Floating around
    Looking forward to seeing your new structure mods. As the above post I am very appreciative to learn from you guys who forged the path for us glass/core newbs
  2. #17
    Dec 2011
    Ludington michigan,on the shore
    Little more progress,and itching today.Click image for larger version.
ID:	425403Click image for larger version.
ID:	425404Click image for larger version.
ID:	425405Click image for larger version.
ID:	425406Click image for larger version.
  3. #18
    Jul 2012
    Lufkin, Texas
    Looking good Bob!
    Josh Peterson
  4. #19
    Dec 2011
    Before this thread goes to far,there is a few things that some may be interested in for a future build.This is an original 1981 comp drag layup.The floor/stringers have never been replaced.The layup goes like this.The hull is a heavy 3/16 thick, I have to be careful where I step! Next up is a 1/2" of balsa set on wet chop strand mat,no bedding compound was used,next is a heavy mat/heavy cloth/heavy mat.For a top skin of 1/8" heavy.Stringers are wrapped in multiple layers of mat and cloth,and about 1/8" per side.The stringers were set ___on top of the balsa floor.___The fit was not very precise as 3/16 gaps under the stringer is common.Im thinking that this boat was built by two people working one, on the port side and one the right,as the right side was obviously built by a better craftsman.As fit finish and lay ups are all better on the right.I did find some water damage but very little,All on the left side,same as the front end damage? maybe two square feet total,so far.
  5. Thanks nitro_rat, W2F a V-King thanked for this post
  6. #20
    Jul 2012
    Lufkin, Texas
    I am always interested in the construction of Hydrostreams. There were so many variations and as you say, different workers with differnt skill levels. I have a 73 Viper and it’s construction is more solid than any of the boats I’ve messed with from the “peak years” of say 78-81!
    Little details like that are gold to me.
    Josh Peterson
  7. #21
    Dec 2011
    What surprised me was the thin hull,and relatively thick floor skin.Im thinking that helped hold off the water intrusion.As most streams are full of pinholes in the floor.
  8. #22
    Jul 2012
    Lufkin, Texas
    Yes, the production boats I have seen have a dry layup over the core. The ones with float boxes have unsealed holes on top where the foam was poured in. A sure recipe for water intrusion!
    Josh Peterson
  9. #23
    Aug 2015
    NE Tennessee
    Yes, my 79 production V-King (Not a Comp) had dry mat over rotted core. It also had open expansion holes on top of the unsealed foam filled float boxes, and I dug out a lot of wet foam. Needless to say the boxes got deleted.
  10. Likes nitro_rat, NICE PAIR liked this post
  11. #24
    Minneapolis MN
    Looking forward to seeing this come together.
  12. Likes NICE PAIR liked this post
  13. #25
    Dec 2011
    Time for a little update.Most of the core is out,still some in the bow, and quite a bit of cleanup.Realy tough going under the dash.Found a lot of rot from the seat box forward,most all on the left side.Got most everything for the repairs ordered,and the stringer material came in today.While I'm on the subject of material I may as well get this behind me. I did not go with composits!! Biggest reason,there is NOTHING stronger than balsa core.the original stringers were five ply CDX plywood.Ill be replacing those with nine ply Hydrotec,and hold it all together with the higher grade S2 cloth and epoxy resin.By doing my own hand layup I believe I can do a proper job of sealing the balsa.The seat box will be framed in 3/8 seven ply Hydrotec.Did a weight before tear down,and will do another when completed.I know when it comes to material most guys have an opinion.Not intending to start a debate,just sharing how I decided to do mine.Oh on a different note I did manage to saw a goshdam hole in the bottom.will cover that in another post.Click image for larger version.
ID:	425649Click image for larger version.
ID:	425650Click image for larger version.
ID:	425651Click image for larger version.
  14. Likes nitro_rat, tnelsmn, rjdubiel liked this post
  15. #26
    Jun 2018
    Floating around
    Wow your making great progress! That last pic really shows how far up the hull your core goes. Mine ends right at the front seats.
  16. #27
    Dec 2011
    There is still a couple more feet to go
  17. #28
    Dec 2011
    Quote Originally Posted by outasite View Post
    I need to ad on to this post.Today after cleaning the floor up a little more I discovered that there is ANOTHER 1/2" of balsa still left in the pad.So the pad only has two layers of 1/2" laminated making it one inch thick! You can see the front of it right by the hammer handle in this picture.Click image for larger version.
  18. Thanks nitro_rat thanked for this post
    Likes nitro_rat liked this post
  19. #29
    Jun 2018
    Floating around
    That sounds ideal are you going to replace the core with the two layer balsa layup?
  20. #30
    Jul 2012
    Lufkin, Texas
    In 40 years people will be lamenting all the ruined composite cores from the turn of the century rebuilds. The ones that were properly done with wood will be the good ones!
    Josh Peterson
