Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 84 of 84
  1. #76
    Mar 2004
    Brooklyn Park, MN
    It looks like he is just pre-coating the balsa first with resin, then once that tacks up he will be putting down the glass. Balsa sucks up plenty of resin, so pre-coat the balsa always first, let that soak in, then add more resin and glass. With epoxy this is easy, with poly resin, you don't get that much time so you need to work fast with poly or vinyl resin.
    1973 Viper w/ V4 Crossflow.
    1978 Viking w/ 1978 175hp Merc, My first restoration in progress
  2. Thanks tnelsmn thanked for this post
  3. #77
    Dec 2011
    Ludington michigan,on the shore
    Wow,that was a big piece to get down and straight! Click image for larger version.
ID:	428332Click image for larger version.
  4. Likes tnelsmn, W2F a V-King, nitro_rat liked this post
  5. #78
    Nov 2003
    Your work looks awesome! Thanks for sharing your progress.
  6. #79
    Aug 2015
    NE Tennessee
    Looking great ! That glass laid in one piece HAS to be strong
  7. #80
    Dec 2011
    Thanks,It was a long day.Took a while to get the drain fitting in place and pulled back to seal.Its hard to work that much 17oz mat at one time and keep it wet. but not to wet,get the air out,and and and.Now it's on to repairing the last cracked stringer. There will be be a splice right behind the seat box pics to follow.
  8. Likes nitro_rat, W2F a V-King liked this post
  9. #81
    Jul 2012
    Huntington, Texas
    Keep up the good work Bob! Yours is one of my favorite 'Streams, nice to see it done right!
  10. Likes W2F a V-King liked this post
  11. #82
    Dec 2011
    Removed the stringer section,and took the rest of the day off. Decided to cook off the epoxy,just to be sure it set properly.Will give it twenty four hours of good heat.Then back at it tomorrow.Click image for larger version.
ID:	428425Click image for larger version.
  12. #83
    Mar 2004
    Brooklyn Park, MN
    Another way other than heat for 24 hours is the way I do this, I think I finished my vking core about 5 years ago........ So she should be cured and good to have the floor put in soon!!!!
    Looks great Bob, I wish you did this 10 years ago so I could have used your techniques.
  13. #84
    Dec 2011
    Well the bright side, is the slower epoxy cures the stronger it is.So by now your Vking should be bullet proof!!!
  14. Likes rjdubiel liked this post
Spinelli Props
