Results 1 to 15 of 24
    Jun 2001
    1969 Mercury 1250 Super BP Racing Outboard
    1969 Mercury Super BP Race Motor – Serial number 2642263
    One of 249 made in 1969, this motor was 100% restored and rebuilt 5 years ago and has never been run since. These original block motors are getting very scarce and hard to find in any condition.
    Powerhead - This is the true SBP block as defined by the serial number, fuel pumps and starter bracket designs. Many “SBP” motors these days have 1350 blocks and are not real SBP powerheads. This powerhead includes all new .015 oversize pistons, rings, bearings, seals, gaskets, you name it and it has been replaced. Entire fuel system and carbs, ignition trigger, wires, everything. Completely stripped, primed and repainted. Brand New inner exhaust baffle plate and inner water jacket baffle plate. All threads chased and heli-coils installed in any questionable locations. All new bolts and hardware were used.
    Mid-Section – Motor does not have the original Mid housing but has a replacement BP mid-section as these were prone to cracking. It has no serial number plate on the mid but the serial number is clearly stamped on the starter bracket on the motor block. This mid ALSO is the correct BP mid as it has no upper mount holes for shock absorbers or trim cylinders. These used a fixed transom fixture to set the trim angle. This motor WILL NOT accept standard power trim rams with the current clamp brackets on the motor. The fixed trim fixture is available for an extra $500.
    Lower Unit - This motor has a MC-1 twin pinion speed master lower unit that has been resealed and pressure tested. Turns very smoothly. You can still find parts for these lowers and they are pretty much bullet proof whereas the original BP lower units were known to self-destruct. The MC-1 lower unit used a 1-inch SHORTER driveshaft than a standard 15-inch mid. Basically it is 14-inch midsection. That requires a shorter mid-section adapter which this motor has installed. Please bear this in mind if you plan to run this. A standard SSM or standard lower unit WILL NOT bolt up to this without a different, one-inch thicker midsection adapter. The MC-1 lower unit was the factory issued lower unit used on the Twister and Twister 1 in line motors, before the SSM came out.
    This motor has been shown at several vintage shows and has one scratch on the top cowling. Otherwise this motor is a 10 out of 10. It has been stored inside in a climate-controlled room (my living room) and turned over and oiled every year.
    I WILL NOT ship this motor. Pickup only. No trades unless you have Mercury 1500XS, T2 or T2X racing stuff.
    $6500
    More pictures available for seriously interested parties.
    Attached Thumbnails Attached Thumbnails Front.jpg   side 2.jpg   100_1791.jpg   crank assembly 1.jpg   new exhaust baffles.jpg
    nice
    Sep 2017
    Ashland city tn
    Piece of art. Glws
  4. Likes NICE PAIR liked this post
    WI
    WOW, Again!.....the V-8 that's for sale just got into a bitch fight with this puppy lol!!
    I have a boat or two.... that I never get to drive
    Dec 2001
    Kicked out of the house like a BAD puppy.......Shame on you ......
    Jun 2001
    lots of interest... but no takers yet .........
    Oct 2009
    Lake Conroe, Tx
    Just curious, did they make the 1250 super bp with pipes also? Or could you get em either way?
  9. #8
    Jun 2001
    All the Super Bp's came out of the factory without the stacks. that was an add on kit that most installed. required additional machining to the block as well.
  10. #9
    Jun 2001
    Bump.
  11. #10
    Gilbert, AZ
    Oh man, I wish I had a late 60's vintage Kober Kat to bolt this on to....
  12. #11
    Jun 2001
    Bump
  13. #12
    Jul 2009
    Liberty,tn
    Tom, I bought your Missle and have a 150 xs on it,1977 sn#4602121. Would you be interested in a trade,it would be a period correct,all 1969, rig. How much cash?
  14. #13
    Jun 2001
    still available....Will throw in the transom fixture with it........
  15. #14
    Black Creek WI
    A 73 viper followed me home the other day, Would love to have the extra scratch to bolt that old girl on it!!!!! VERY COOL PEACE OF ART FROM DAYS LONG PAST!!!!!!!!!!! GLWS
    1994 Brad Collins Mirage Jag.with 1990 2.4 BP E.F.I Offshore
  16. #15
    Mar 2010
    Grand Rapids, MI
    Are you sure you won’t ship it?
  1. 1969 Merc 1250 possible super bp?
    By Dpate94 in forum Outboard and Racing History
    Last Post: 04-30-2018, 08:41 PM
  2. 1969 Mercury 1250 problem
    By Carter Powell in forum Technical Discussion
    Last Post: 06-29-2016, 09:08 PM
  3. Mercury Tech: 1969 ish mercury 1250 timing.
    By taz081581 in forum Technical Discussion
    Last Post: 03-20-2011, 02:02 PM
  4. original 1969 Mercury 1250 Super BP.
    By ssmith007 in forum Outboard and Racing History
    Last Post: 03-02-2008, 07:22 PM
